Mm 1987 Mini Advantage @ Mill Road Garage Iow
464 replies to this topic
#61 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 September 2020 - 08:06 AM
Here is yesterdays progress.
Next job was the replace the left hand arch tub.
Here it is cut out
And the new one trial fitted.
Once I was happy with the fit, I cut out this rusty section to replace with new metal
And replaced it
And then sprayed everything up with zinc and clamped in the tub
Spot welded the arch lips together
Plug welded the end of the bulkhead and companion bin to it
And popped the slug of weld to the stiffener completing the instalation
Next to go is the boot floor
As the valance, closers and back panel are completely shot, It can all go together
That's the floor gone, next is the seat base section
At this point, I spot welded the stiffeners to the arch tub
Next up is to prep for the new boot floor
Ben
#62 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 10 September 2020 - 08:28 AM
Great work Ben , it brings back memories of my mini being done in the same sequence, as always you make it look so straightforward.
#63 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 10 September 2020 - 02:16 PM
Top quality work as always
#64 JAYSONIC 79 IOW
JAYSONIC 79 IOW
  • 29 posts
Posted 10 September 2020 - 06:38 PM
Great work Ben
#65 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 September 2020 - 12:11 PM
This morning has been spent cleaning up and prepping all of the edges that the boot floor was attached to and removing all the snaggy bits of floor that was left behind.
And now the prep can begin on the new floor.
It needs a minor modification here
And then we have to transfer this over.
I have removed the battery earth fitting and sand blasted it ready to fit
I'll finish that up this afternoon and start fitting it to the car.
Ben
#66 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 September 2020 - 04:27 PM
I cleaned up the tank strap bracket
And welded it to the new floor
Along with the earth strap captive
Then welded up the injection fuel line grommet hole
And then trial fitted the floor into the car
Overall, it fits very well but I was a tad concerned with the way the ends met the back of the quarter panel.
This is how it should be
But the other side is like this
I am certain that everything is in the correct position and that this must be a fault with the new floor so I tried on a half rear panel to check
This isn't the panel I will be using on this car but it demonstrates that everything is ok with the position
The bumper holes line up perfectly
With that confirmed and the back panel removed again, I prepped the new subframe so I can trial fit it.
This is just sandblasted original trunnions with new pins, bushes and hardware
And into the car
It went straight in and the bolts dropped through easily so I'm calling that sorted.
Next time, I shall finish the prep on the boot floor and get it welded in!
Ben
#67 Avtovaz
Avtovaz
  • 1,231 posts
Posted 11 September 2020 - 07:40 PM
wow glad you showed the bit about the rear panel mate, mine was the same! Thought it was me!
#68 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 September 2020 - 08:02 PM
Most of the panels have some kind of issue that can make you think you got it wrong.
all I'll do with this is modify that end slightly to extend it over so that it doesn't pull the quarter over
#69 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 11 September 2020 - 10:46 PM
Do you remove the black E-coat, or just prime over it?
#70 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 September 2020 - 11:11 PM
Sometimes I do but only if there is rust beneath. That doesnt tend to happen now but used to be common.
Generally speaking, e-coat does not need to be removed prior to painting unless it is damaged.
Ben
#71 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 16 September 2020 - 08:45 PM
Some nice work there.
#72 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 September 2020 - 04:39 PM
With the frame removed again and the floor taken back out, it's time to finish prepping the boot floor for its final fit.
Holes were drilled for the fuel supply and breather
And then it was time to work on the valance closers. I like to fit these to the floor before the floor goes in for ease of access.
Stupidly, I ordered the valance closers without the side closer and reinforcing plate.
It made more sense to just fabricate these parts than wait for replacements.
Pictured here is the prepped floor, the valance closer and the reinforcer I made up
First the reinforcer is spot welded to the floor
Followed by the closer
And then the same for the other side
Then I needed to make up the side closer and as this follows the curve of the valance, I decided it would be a good idea to clamp that to the floor. I just used the bumper mounting holes to line it up
The side closer goes here
And my homemade one clamped in place
And welded
Here is one for the other side
Which I fitted next
And then the floor is ready to go
In it went and all clamped up
Once it was all lined up and the subframe refitted, I started by welding the arch to floor reinforcers.
Then the seatbelt plate was welded to the floor as per factory spec
Then the arch to bulkhead reinforcers were welded to the floor. Again, as per factory
At this point, the sub frame can come back out enabling me to spot weld the arch tubs to the floor
And the multilayer sandwich of floor, valance closer and arch tub either side
Just the seat base section to weld to the rear bulkhead and companion bins
I finished up by lowering the car on the stands ready for the next stage
Ben
#73 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 September 2020 - 09:40 PM
A little bit done today.
Wiring harness tabs made and welded into place
Bottom of the rear bulkhead welded to the bppt floor and linished back
And then the sides of the seat base were spot welded to the companion bins
#74 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 September 2020 - 04:48 PM
Todays task was to remove the remains of the back panel ready for the new one.
First up, I drilled the spot welds around the window frame
And then I cut just under the gutter and just inbound of the rear seam with a disc cutter to remove the bulk of the panel
Then there is the remains of the seams to remove and clean up starting with the roof gutter
I just grind through the roller welds with a flap disc until its thin enough to peel away
And then after a clean up, it's ready to go
And then I used the same method to remove the remains of the seams from the side panels and cleaned everything else up
And then tried the new back panel on
Next stage is to get everything on the back end including the inside of the back panel and valance prepped up for epoxy.
Easier to do this now than once its welded to the car.
Ill post up when its done
Ben
#75 floormanager
floormanager
  • 681 posts
  • Local Club: Mini Club Sussex
Posted 22 September 2020 - 07:47 PM
Didn't realise there are two layers of steel for the roof
    Bing (3)
