Mm 1987 Mini Advantage @ Mill Road Garage Iow
464 replies to this topic
#391 Richard e
Richard e
  • Just Joined
  • 103 posts
Posted 29 April 2021 - 07:57 AM
Hi Ben
Are you making any modifications to allow for E10 fuel?
Richard
#392 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 April 2021 - 12:27 PM
Hi Ben
Richard
All I have done is replace all rubber with ethanol resistant which should be sufficient.
Ben
#393 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 April 2021 - 06:33 PM
Today, i have put in new antidrum pads on the floors.
Its amazing the difference this stuff makes.
There is little else i can do on the interior at the moment as I'm waiting for carpets, seats and the headliner.
I put the grile on as I'm all done up front now.
And hung the passenger door
Then the owner showed up with the new wheels so they went straight on
I have also been installing a few minor mod cons.
Its useful to have somewhere to charge your phone and a means to listen to music but it would be a shame to spoil the basic stripped back look of the interior with head units and speakers.
For usb charging, I installed this 2 way unit under the dash using a bracket I knocked up.
Easy to reach but can't be seen here less you look up from beneath.
As for music, we went for a bluetooth amplifier which I have installed under the panel shelf
The instalation isn't complete yet as I am waiting on the speakers.
The parcel shelf will be covered with a custom board so that the speakers aren't visible.
Ben
#394 cooperd70
cooperd70
  • 730 posts
Posted 30 April 2021 - 06:48 PM
Another build that looks like it's going to be fantastic!! 👍👍
#395 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 01 May 2021 - 09:39 AM
Every time I see one of your posts Ben the workmanship always impresses. You seem to treat the customers cars like they were your own. Top work!
#396 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 May 2021 - 03:35 PM
Progress has slowed right down on this mini due to waiting for a delivery of carpets and headlining.
In-between other jobs, I have been adding a few more parts to it.
These are.
Build up passenger door with glass and regulator
Fit drivers door and build up with glass and regulator.
Fit airbox and choke cable nipple
and I have fitted a mk1 bootlid handle!
There was work to the door drop glasses that had to be done too.
This involved removing the very 90s blue window tint film and replacing the metal lift bars on the bottom of the glass.
I've been absolutely rubbish at taking enough photos again so I'll take some next time of the other bits.
Ben
#397 wingnut
wingnut
  • 464 posts
Posted 20 May 2021 - 03:45 PM
As usual Ben this is looking fantastic.
Could i ask, where do you get the antidrum pads from and also the bluetooth amplifier and usb 2 way unit please?
#398 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 May 2021 - 04:02 PM
Cheers for the compliments.
The antidrum is from my paint supplier but j dknt have a part number. You could try an automotive paint supplier near you.
The usb is from amazon but I can't generate a link for some reason.
The amp is from here https://www.classiccarstereo.co.uk
Ben
#399 JXC Mini GT
JXC Mini GT
  • 852 posts
Posted 20 May 2021 - 04:06 PM
I do like the  colour scheme of this Mini and the alloy wheels really suit the car, great work as always Ben, a smiffys bits air filter finisher might suit as well?
#400 JXC Mini GT
JXC Mini GT
  • 852 posts
double post
Edited by JXC Mini GT, 20 May 2021 - 04:08 PM.
#401 wingnut
wingnut
  • 464 posts
Posted 20 May 2021 - 06:28 PM
Thanks Ben,i'll look into it.Keep up the great work
#402 colinf1
colinf1
  • 1,028 posts
Posted 20 May 2021 - 06:48 PM
...replacing the metal lift bars on the bottom of the glass...
Did they come off easy? When I was cleaning my glass I couldn't get them to budge,was afraid of smashing the glass...
#403 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 20 May 2021 - 06:56 PM
I pry a screwdriver inbetween with some tape wrapped around it, levers off quite easily.
#404 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 May 2021 - 07:16 PM
I actually had to resort to covering the glass with a welding blanket and then cutting them off with a slitting disc.
They just wouldn't budge no matter what I did as they had corroded and expanded the rubber very tightly onto the glass.
Ben
#405 johnR
johnR
  • 2,302 posts
Posted 21 May 2021 - 01:10 PM
Not wishing to put Smiffy's nose out of joint but I prefer the look of the DSN airbox finisher
