Mm 1987 Mini Advantage @ Mill Road Garage Iow
464 replies to this topic
#346 Magneto
Magneto
  • 891 posts
  • Local Club: KC MINI Club
Posted 06 March 2021 - 12:42 AM
How do you get the wheelboxes apart? It looks like the only way to get to the shafts is to melt the solder on the end of the part the arm attaches too?
#347 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 March 2021 - 08:56 AM
I wish I'd taken photos now.
Basically, you remove the wheel box from the cable and with the back off the wheel box, you will see the wheel which is just pressed into the shaft which is splined.
I put it in the vice and drifted the shaft down from the wheel end until it finally came out the other end.
Once it was cleaned up, I pressed the shaft back into the wheelbox body using the vice jaws and then tapped the wheel back onto the splines.
Ben
#348 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 March 2021 - 04:38 PM
I've been working on this in the background and have something worthy of an update.
The 998 for this car is going to be refitted for the time being although there are plans for something bigger in the future.
I've not heard this engine run and am not sure when it last ran but I do know its been off the road since 2007 so before I spend time cleaning it up and painting it, I need to know if its any good.
I fitted a new fuel pump and rebuilt the carb and then set to starting it on the workshop floor using a fuel can as a fuel supply and a jump pack to provide volts.
Surprisingly, it started right up and idled happily on the pallet.
No nasty surprises and no oil leaks so this engine will be fine.
Its UGLY though!
I'm not going overboard with it. I'm going to keep it simple so I will first strip off the ancillaries, clean it up and then paint the whole thing mowog green with some gloss black accents.
Should look good.
Ancillaries off first
And then a degrease
Before removing the last few bits
Once its painted  ill give it a service and that should be that.
Ben
#349 JAYSONIC 79 IOW
JAYSONIC 79 IOW
  • 29 posts
Posted 18 March 2021 - 10:10 AM
Little gem glad we could save it Ben cheers !
#350 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 March 2021 - 01:58 PM
I didn't get the engine painted as soon as if have liked.
Reason being, I removed the pot joints and discovered lots of axial play in one of the output shafts.
Took the diff out and discovered the shims had disintegrated.
I spoke to Bill Richards and he supplied a fully rebuilt one ready to go in.
With that done, I have it a final degrease and hung it in the booth
And then started by applying 2 costs of acid etch
And then 2 coats of BMC olive green
And I also did the rocker cover and oil filter housing
That should give the engine bay that early period look
Ben
#351 johnR
johnR
  • 2,322 posts
Posted 29 March 2021 - 03:59 PM
Very smart! A nice acid yellow waterpump pulley will set that off a treat!
#352 JAYSONIC 79 IOW
JAYSONIC 79 IOW
  • 29 posts
Posted 29 March 2021 - 06:47 PM
Looks very smart that Ben
#353 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 March 2021 - 05:08 PM
Got some more bits cleaned up for paint
And then after fitting a few bits back to the engine, it went back into the car
rbXiqb6.jpg?1
And some of the parts I cleaned up and painted this morning went back on too
Including the new stage 1 manifolds
Ben
#354 floormanager
floormanager
  • 803 posts
  • Local Club: Mini Club Sussex
Posted 30 March 2021 - 07:46 PM
Brings back some recent memories for me. Looking good
#355 JAYSONIC 79 IOW
JAYSONIC 79 IOW
  • 29 posts
Posted 30 March 2021 - 08:00 PM
Now that’s an engine cheers Ben .
#356 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 April 2021 - 02:15 PM
Today I painted the roof.
Rover NMN diamond White
And the started getting the fuel tanks ready to paint
The original was quite scabby externally but overall sound.
Once preped, here it is painted along with the new r/h tank
And then some other bits. L/h tank strap, seat anchors and engine steady bars
Ben
Edited by Ben_O, 01 April 2021 - 02:16 PM.
#357 cooperd70
cooperd70
  • 793 posts
Posted 01 April 2021 - 03:45 PM
It's all looking great as always Ben! Wish my engine gleamed as that one does 🙂
Edited by cooperd70, 01 April 2021 - 03:45 PM.
#358 Matlock Mini
Matlock Mini
    Just On Tickover
  • 9 posts
Posted 01 April 2021 - 04:34 PM
Hi Ben.. Fantastic repair work you do, Im wondering what the big slab of metal is you have clamped to the back of your rear quarter repair.. is it for dressing or do you use it while butt welding to stop distortion etc?
#359 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 April 2021 - 04:43 PM
I can't find the bit you mean but I assume you are referring to the sheet of copper.
This is to give something to weld against not only to minimise blowing but mainly to reduce distortion.
Its also good to keep the two edges clamped tightly down evenly.
Ben
#360 Matlock Mini
Matlock Mini
    Just On Tickover
  • 9 posts
Posted 01 April 2021 - 05:32 PM
Hi.. I thought it looked non-ferous and i assume it prevents excessive penetration too..
Thanks for the advice I will have to find a piece
Jeremy....
    Bing (1)
