Mm 1987 Mini Advantage @ Mill Road Garage Iow
464 replies to this topic
#286 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 25 January 2021 - 09:33 AM
Is it just me or does anyone else like the colour of the shell in primer ??
Maybe a rub down and layer of lacquer on that then Ben ??
You aren't the first person to say that!
#287 GraemeC
GraemeC
  • 7,425 posts
Posted 25 January 2021 - 10:58 AM
What are the larger holes that will be under the moustache for Ben?
#288 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 25 January 2021 - 01:00 PM
That, I don't actually know.
There were 2 red caps in them on the old panel so I imagine they were used perhaps up until a certain year and then blanked off.
Ben
#289 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 25 January 2021 - 04:04 PM
#290 JAYSONIC 79 IOW
JAYSONIC 79 IOW
  • 29 posts
Posted 26 January 2021 - 01:33 PM
Lol I thought that the other night I quite like that colour that’s on it at the moment
#291 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 26 January 2021 - 05:53 PM
Looking excellent Ben, did you have to space the moustache fixing screws away from the front panel.
#292 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 27 January 2021 - 01:21 PM
No.
For the mock up, I used screws on the clips instead of the rivets.
Admittedly they are a very tight fit and each one took me 10 minutes of sweating and swearing to get them to clip on bit once they were, they were difficult to remove again which is great
#293 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 27 January 2021 - 03:14 PM
Nothing too exciting going on right now.
I have started the prep of the exterior panels which involves flatting the primer back.
First off, a guide coat is applied
And then it is flatted back. The guide coat shows up all the imperfections in the body and the idea is that if the imperfections are minor, you keep flatting until they blend in.
Once done, I like to mist the panels with panel wipe to give them a shine. Then you can see a lot better how straight the panels are
And the front is done
I have also done down one side.
Ben
#294 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 27 January 2021 - 04:50 PM
And that's the other side done too.
#295 cookie4343
cookie4343
  • 2,257 posts
Posted 27 January 2021 - 04:52 PM
Always love looking at you work and love you always do it properly. In regards to my previous question, I meant the grill surround not the whiskers but that did answer another question. The guide coating and blocking the epoxy primer is exactly how I did my golf and it amazed me how many imperfections I found that I couldn't feel with my hand.
#296 cookie4343
cookie4343
  • 2,257 posts
Posted 27 January 2021 - 04:54 PM
Is that a durablock I see. Best blocks I've ever invested in.
#297 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 27 January 2021 - 05:01 PM
Cheers!
The frame is ok but I did need a spacer on the bottom each side.
And yes, durablock. They are really good.
Ben
#298 blacktulip
blacktulip
  • 6,224 posts
Posted 27 January 2021 - 09:15 PM
So clean and those gaps are perfect!
#299 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 02 February 2021 - 11:59 AM
After spraying up a test panel, we now have a final decision on the colour
#300 eric67
eric67
  • 113 posts
Posted 02 February 2021 - 01:11 PM
Great choice. Is that Island Blue?
