Mm 1987 Mini Advantage @ Mill Road Garage Iow
464 replies to this topic
#256 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 January 2021 - 12:44 PM
Top restoration work Ben, better than they left the factory.
You need to to have a YouTube channel, it would be very useful.
Cheers.
Doing a youtube channel might be fun, however I just dont have the time to create and edit content.
Ben
#257 Jase
Jase
  • 1,169 posts
Posted 17 January 2021 - 02:41 PM
Cheers.
Ben
I prefer the updates in the forum, not keen on flicking back and forth to you tube, good to see a written commentary. Amazing work Ben.
#258 Project_Green
Project_Green
  • 24 posts
Posted 17 January 2021 - 04:39 PM
Love this thread Ben so inspiring.
#259 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 January 2021 - 05:42 PM
On with the bootlid.
I have finished repairing the various dents and applied some epoxy primer.
Next up,I drilled the holes to mount the new badges
yy6kKut.jpg?1
Then the buffers for the number plate frame
I also added a hole for the wiring loom
Next the hinges for the number plate frame using rivnuts
And that completes the modification
Looks great on the car
It's not legal to drive with the bootlid open but the hinged number plate is a nice touch.
#260 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 January 2021 - 07:44 PM
Cast your minds back a few pages when I was mocking up the front end.
This is the style we were going for
Looked great but no quite retro enough so a new plan was hatched and this was purchased
Mr2V0G8.jpg?1
In order to fit this, I first removed the lip from the front of the bonnet
And then the grille, frame and whiskers could be aligned, mounting holes drilled and then screwed in place
I think it looks loads better
Ben
#261 JXC Mini GT
JXC Mini GT
  • 891 posts
Posted 19 January 2021 - 08:11 PM
Looking good Ben, what colour is the paintwork going to be ?
#262 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 January 2021 - 08:13 PM
BLMC Island blue with Rover NMN white roof.
Ben
#263 JXC Mini GT
JXC Mini GT
  • 891 posts
Posted 19 January 2021 - 08:18 PM
Is that the same colour as the MPI you did a while back?
#264 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 January 2021 - 08:22 PM
No, that was Aston Martin flugplatz blue.
This colour is the same as the blue mk2 cooper belonging to floor manager.
Ben
#265 JAYSONIC 79 IOW
JAYSONIC 79 IOW
  • 29 posts
Posted 19 January 2021 - 09:46 PM
Looks so much better Ben great work
#266 blacktulip
blacktulip
  • 6,231 posts
Posted 20 January 2021 - 12:37 AM
Outstanding work
#267 Project_Green
Project_Green
  • 24 posts
Posted 20 January 2021 - 09:51 AM
With the grille and bonnet back off, there is this bracket to go on for the clutch line and engine steady
And thats the front conmplete
Next up, door skins
Ill start with the worst one
First the door needs stripping
Hinges come off first
Followed by the locks and associated parts
To get the old skin off, I need to drill these spot welds
Cut these welds
And then grind through the edge of the skin fold all the way round like this
There may also be some spot welds securing the skin to the frame in places around the edge but they don't put up much fuss so not really worth locating and drilling in my opinion.
And that's the skin off
Leaving the frame for me to repair
I start by cleaning up the areas that don't need to be cut and replaced
And then I begin by making up pieces for either end at the bottom starting with card templates
And in
And the other end
And then the middle
Then I can try on the new skin
It all seems to fit well. The next stage is to partially fold the skin on so it can be tried on the car for fit but first I want to epoxy prime the frame and the inside of the skin.
That's just been done and is drying as I type.
More tomorrow.
Ben
 Ben How to you get your ground down weld to look so smooth?
#268 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 January 2021 - 10:20 AM
I finished mocking up the back end just to make sure that everything fits as it should before paint.
Only issue to note is that the petrol cap doesnt fit the reproduction right tank.
I'll sort something
Ben
#269 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 January 2021 - 10:23 AM
[quote name="Project_Green" post="3681002"
 Ben How to you get your ground down weld to look so smooth?[/quote]
Lots of patience, time and using various grades or sanding disc to gradually bring it down flush
Ben
#270 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 January 2021 - 10:35 AM
Wing mirrors
    Bing (1)
