Mm 1987 Mini Advantage @ Mill Road Garage Iow
464 replies to this topic
#181 JDImini
JDImini
  • 683 posts
Posted 06 November 2020 - 10:04 PM
Bit late to the party on this one, great work Ben, as always!
Just need to say
Attached File  3-waynes-world-quotes.jpg   19.76K   1 downloads
How inadequate do I feel I can't even fix a chuffing leak in the boot of my Seat Leon  :rolleyes:
#182 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 November 2020 - 10:12 PM
Just need to say
Hey Darren.
How are you guys doing?
Thanks for the compliments.
Hows Jack's mini?
#183 JDImini
JDImini
  • 683 posts
Posted 06 November 2020 - 10:33 PM
We're all good, mini's looking as fresh as when we picked it up from you. Just about to have a 1293 heart transplant  :-)
Attached File  IMG_6034.jpg   103.51K   1 downloads
Edited by JDImini, 06 November 2020 - 10:44 PM.
#184 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 November 2020 - 12:00 AM
Brilliant! Hope you enjoy it.
I have a mini in at the moment that I've just put a 1293 in and the owner has asked me to put on the running in miles for hom so that's nice.
It goes really well.
#185 blacktulip
blacktulip
  • 6,231 posts
Posted 07 November 2020 - 01:06 PM
Superb progress Ben ?
#186 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 November 2020 - 07:41 PM
Great work Ben, lovley job. Are the door skins genuine or non genuine.
I’ve just fitted magnum door skins to mine, they fitted as well as the heritage ones in my opinion and are half the price, I bought them from mini sport
These were non genuine ones.
I have always found heritage ones to be very good but no harm trying these ones and I'm glad I did.
Edited by Ben_O, 07 November 2020 - 07:44 PM.
#187 slidehammer
slidehammer
  • 1,205 posts
  • Local Club: LSMOC
Posted 10 November 2020 - 03:18 PM
Ben,
I know you mentioned you were using some pattern panels on the front end, do you think they were worth the cost saving in the end?
I ended up using the following pattern parts.
A panels
Wings
Front panel
Door skins
1 step
The a panels are absolutely fine, the wings and front panel need some twisting and minor mods but mainly time.
If you have the time, then they are worth the saving.
The step isn't as crisp as a genuine one but looks fine and fits well.
I was surprised and impressed with the door skins. They needed some minor tweaking but you will get that with most minis as they are all slightly different, particularly if the car has had other panel work to the surrounding panels.
They are definitely worth the saving.
Ben
Thanks Ben, your opinion is always highly valued
#188 Sam76
Sam76
  • 40 posts
Posted 19 November 2020 - 11:04 PM
I’m starting to get worried now Ben! Haven’t seen an update on this one for a good while! I’m getting withdrawals!!
#189 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 November 2020 - 01:13 PM
I know, tell me about it.
I'm itching to continue with it but I was away last week and this week has been other bookings.
I did some restoration work on an MGB recently and the car was being reassembled elsewhere to keep the cost down. That's back with me this week for me to flat and polish so that's keeping me busy! The owner also changes his mind about the mirrors so I had to weld up the mounting holes in the doors and repaint those too.
I'll be back in the advantage next week now.
Ben
#190 Sam76
Sam76
  • 40 posts
Posted 20 November 2020 - 05:10 PM
Good to hear! Looking forward to it!
#191 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 November 2020 - 05:53 PM
I didn't realise I hadn't taken pictures of the passenger door before I started to repair it.
It was pretty much as bad as the other side but instead of big holes in the skin, the bottom of the frame was more rotten.
As the process is the same as the other side, I just have a photo of the finished frame
And now both the frame and new skin are in primer
I shall fit the skin in the morning and try it on the car.
Ben
#192 Johnmar
Johnmar
  • Just Joined
  • 176 posts
Posted 24 November 2020 - 06:26 PM
Are two draining holes enough in a door. (honnest question as I'm pondering if I should add more to prevent doorskin rust from the inside as much as possible..)
Edited by Johnmar, 24 November 2020 - 06:26 PM.
#193 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 November 2020 - 07:44 PM
I'm yet to add the 3rd.
I'll do that before the skin goes on.
I added the outer ones to the repair pieces before I welded them in but the centre section I made separately and didnt drill the hole
#194 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 November 2020 - 04:15 PM
I started off this morning by uniting the skin with the frame
And then once folded, its ready to go on
Once I had blasted the hinges, spacers and spreader plates, the door went on for the first try
Not too bad but the skin needs to come back slightly and the front profile doesn't match the A panel...
After a play about and slightly reprofiling the edge of the A panel, its much better
The profile at the back of the skin doesn't match the quarter panel so I used some 2.4 steel welding filler rods to add material to the skin in the correct profile
And then once fully welded on and ground up, the profile can be fine tuned to match
And that finishes that off
I then finished this repair
And sorted out the missing bit of gutter here
And that's this side done
Very minor stuff to go now before I can start getting it ready for paint!
Ben
#195 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 November 2020 - 05:49 PM
I think the next stage is going to be to get this back on the spot to finish off the last bits and pieces.
Before I do that,I want to prime the engine bay so that I can bolt the spit frame back in and then it can stay in.
First off is to prep up and applyasmidge of stopper in the couple if remaining Pitts.
And then sandblast the hinges
And then in with the epoxy
Ben
