Mm 1987 Mini Advantage @ Mill Road Garage Iow
464 replies to this topic
#151 gaspen
gaspen
  • 938 posts
Posted 30 October 2020 - 08:27 AM
In my very amateur view bolting the front panel to the teardrop mounts is useful to hold it in place,it cannot reliably fix its location as there are too many variables(subframe mounts accuracy of new panel etc)The sheetmetal is cosmetic,make it fit where it looks right then worry about bolting it up,after all some cars had teardrop mounts "shimmed" from the factory.Also regards heritage vs pattern if you have to cut the panel at all it may as well be the cheapest.Just my paupers DIY views.I understand entirely if others strive for perfection and I salute them.Steve..
My car don't have teardrops mounts as it is an Mk3
#152 sonscar
sonscar
  • 2,993 posts
Posted 30 October 2020 - 08:45 AM
Sorry I am not familiar with earlier models.So what does the front panel bolt to?Steve..
#153 gaspen
gaspen
  • 938 posts
Posted 30 October 2020 - 11:07 AM
Simply there is no teardrop mount beetween the front panel and the front subframe. They are just bolted to each other with two 3/8 screws.
#154 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 October 2020 - 05:40 PM
With the gaps near enough, I wanted to hold the wings firmly to the front panel and loose all the grips that were holding it together.
I added some tack welds dressing the panels together as I went
Then I could take off the front end as a complete piece
Then make a start getting the scuttle panel fitted permanently
First is to mark and make the cuts for the joins
And then clean up ready for fitting
Next up was to prep the scuttle for welding by cleaning back the e-coat from the join areas and apply zinc
And then once I was ready, I gave the top half of the bulkhead 2 coats of epoxy
And the same for the underside of the scuttle
And once dry, I fitted it
Then I put the front back on, played about with the fit a bit and it's now pretty much there
Now I can align and weld on the A panels
That side was done before I fitted welded in the scuttle but I did forget about the other side...
Here it is after the front went back on and clamped in place
Next is to weld it but I'm out of time today
Ben
Edited by Ben_O, 30 October 2020 - 05:41 PM.
#155 gaspen
gaspen
  • 938 posts
Posted 30 October 2020 - 07:03 PM
Ben, one thing that I don't understand : you clean the welding surface, then apply zinc on it, and finally spray it with epoxy ? I learned that epoxy is better on bare metal or sanded E-coat. My experience with welding zinced area is that it will spatter and leave a poor plug weld.
What do I know wrong ?
#156 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 October 2020 - 07:50 PM
The epoxy is only applied to the non weld areas.
I apply the zinc to the weld areas first,mask off those areas and then apply the epoxy.
As for weld reactions with the zinc, I have had that in the past with some primers. The one I use now doesn't interfere at all with either mig welding or spot welding.
I think it's to do with the zinc quantity. The higher, the better
Edited by Ben_O, 30 October 2020 - 07:51 PM.
#157 JAYSONIC 79 IOW
JAYSONIC 79 IOW
  • 29 posts
Posted 30 October 2020 - 09:05 PM
Coming together now Ben great work
#158 steeley
steeley
  • Just Joined
  • 623 posts
Posted 31 October 2020 - 06:52 AM
are you going to put a new skin on the drivers door. or try and repair the original :D
#159 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 October 2020 - 08:59 AM
New door skins for both sides and frame repairs I'll be needed too.
Ben
#160 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 November 2020 - 12:22 PM
Been back to it the past few days but haven't had a chance to upload progress here.
Last time, I was going to weld on the left A panel
Next up was to blank off the Ariel hole
I also cut the front of the wing to even out the gap but only have an after photo for some reason
There is a bit of an issue here with the front panel. its got a chunk missing!
So I fixed that
And this isnt right despite the top of the wing and A panel being exactly where they need to be
So that was fixed too
With the front back off again, I went to fit the scuttle gussets but then couldn't find them. I realised that I hadn't ordered them so decided to make them instead.
And of course I did the other side.
Now the inner structure is completely done
So I coated it and the inside of the front end in epoxy
And then put the front back on for the last time
And then began the welding.
Not forgetting the straightener between the A panel and wing
Then after doing the same the other side, I did the wing to inner wing joins
Subframe back out
To do these bits
And the other side
I need to take the bonnet off for the next part and it wont be going back on until later so I used this opportunity to try the grille and see if it all fits properly
It's all pretty even but there is room for slight tweaking later.
Ben
#161 Sam76
Sam76
  • 40 posts
Posted 04 November 2020 - 02:11 PM
??? this is car porn!
#162 gaspen
gaspen
  • 938 posts
Posted 04 November 2020 - 05:41 PM
Hello
Did you slice the front wing something like this ?
Attached File  hPTFtea.jpg   40.51K   5 downloads
#163 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 November 2020 - 07:04 PM
Yes, that's right
Ben
#164 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 04 November 2020 - 07:50 PM
Great work Ben, it's a masterclass in replacing/repairing the front end of a mini.
#165 gaspen
gaspen
  • 938 posts
Posted 05 November 2020 - 04:34 AM
Yes, that's right
Ben
That was my idea also. So this modification is approved ?
