1992 Orange Modified Mini
2 replies to this topic
#1 monkeymonk
monkeymonk
  • 367 posts
Posted 24 June 2020 - 11:35 AM
I'm after a rough valuation for my 1992 fairly modified beloved orange mini.
It has been looked after very well, but it’s time to let it go to a new home as I barely use it.
Think i'll need to take better pictures too!
Oil+oil filter, spark plugs, HT Leads, distributor cap, coolant, headgasket, rear brake shoes, brake fluid, front knuckle joints and various bushes have all been changed/replaced this year.
All tyres are in very good condition. MOT due 20th May 2021
Had some welding done on the engine steady bracket last year, as it started to split.
Current mileage is approx. 76100, but new digital dash clock only shows 7100. Mileage will increase a little.
10 Previous owners, I’ve owned it for the past 8 years.
I have a folder full of paperwork!
Long list of modifications: I’ve probably missed a few off.
1330cc engine
Omega 10cc Dish pistons+60set
HIF44 Carb
Swiftune SW5-07 Cam
123ignition electronic distributor system
Maniflow 1 ¾” Monza exhaust system
Pro-flo LCB Manifold
Fletcher Radiator
Facet fast road fuel pump
Filter King fuel filter
Minispeed Belt Drive Vernier kit
ARP Head Stud set
Alloy front subframe mounts
7.5” 4 Pot Calipers with discs and pads
Poly bushes used all around
Fully adjustable suspension
Gaz Shock absorbers
Quickrack 2.2
Adjusta Ride kit
New rear subframe in 2006
Adjustable Rear track and camber brackets
Group 5 Race wheel arches
Removable bonnet held in by 4 pins
10x6 Weller wheels
Mk1 Grille and tash
Heko Wind Deflectors
Comes with a spare set of wheels for when it’s sat for a while
Digidash2-LITE
Bucket seats
OMP 4-Point harnesses
Re-trimmed door cards and dash
Astrali Wheel
Lowered steering column
Central panel with all light switches etc.
Bad bits:
Rust spots! Drivers side A-Panel, Scuttle panel and wings.
Paint chips on the front of car and bonnet.
Exhaust could do with quietening down, great around town/country roads, but can get a bit much after an hour or so on a motorway!
Slight oil leak from somewhere, but can’t figure out where.
Fuel gauge isn’t the most accurate.
Attached File  IMG_20200404_170915.jpg   47.03K   1 downloadsAttached File  IMG_20200404_170943.jpg   49.09K   1 downloadsAttached File  IMG_20200404_171009.jpg   47.21K   2 downloadsAttached File  IMG_20200404_171100.jpg   48.42K   4 downloadsAttached File  IMG_20200404_171212.jpg   91.88K   4 downloadsAttached File  IMG_20200404_171252.jpg   77.07K   1 downloadsAttached File  IMG_20200404_171521.jpg   68.24K   0 downloadsAttached File  IMG_20200404_171804.jpg   51.35K   1 downloadsAttached File  IMG_20200404_171815.jpg   62.46K   1 downloads
Edited by monkeymonk, 24 June 2020 - 11:36 AM.
#2 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 24 June 2020 - 02:19 PM
That looks ace I love it. No idea of value sorry and all the bad bits you have mentioned are just confirming that fact it is a mini
#3 monkeymonk
monkeymonk
  • 367 posts
Posted 25 June 2020 - 08:50 AM
Thanks! Will be sad when it sells
