1983 Mini City
#91
Posted 17 December 2020 - 09:05 AM
#92
Posted 17 December 2020 - 02:58 PM
I thought I had ordered a scuttle panel, but I must have removed it from my cart before placing order. Will try to remove the existing scuttle with a small Dremel cutting disc to cut at A pillar, drill out spot welds, then try to remove full front in one go....
#93
Posted 18 December 2020 - 05:27 AM
16mm bar, through the guide sleeve with a pilot on the end of bar that matches up with pilot hole on end of adjustable reamer, everything is a nice snug fit
#94
Posted 22 December 2020 - 05:27 PM
New bearing pressed in with the help of M16 threaded bar....but looked around and noticed the plastic sleeve...doh! Forgot to put it in...
Tried to tap out the bearing gently but wasn't successful, pinched a bit of the casing and caught one of the needles.
You can see one of the needles pushed outwards against the casing..
Took the bearing out of the repair kit for the opposite side to at least get one side finished.
All assembled and touched up any paint chips...
#95
Posted 01 January 2021 - 05:25 PM
Decided to start taking off the front end, drilled out all the spot welds on the drivers wing to avoid any further damage to the inner wing. Passenger side was easier as I just cut through the inner wing.
I didn't even need to do much to get passenger A panel off, literally fell off after I removed wing.
Inner wing was very difficult to remove, thanks to the dodgy repair that had been done. A patch was weld to the inner and outer A posts, then was losing light so couldn't see where spot welds where along floor panel, so nipped it off an inch or so into the inner wing.
A bit of cleaning up to do on the cross member, next I'm planning on removing the scuttle panel to get better access to the top of the inner wings and closing panels
#96
Posted 10 January 2021 - 03:55 PM
No joy, contact adhesive will come off with white spirit but the staining that has gone through the preferrated material and the overspray is just too much to try and save it, time for the bin unfortunately.
Even it rods are a bit rusty, need a good cleaning but salvageable.
#97
Posted 10 January 2021 - 05:24 PM
These almost came up as good as new...
Someone was a bit heavy handed with the glue...
Overspray, glue weeping through and rust staining...
#98
Posted 23 January 2021 - 06:00 PM
Will turn it into a garden feature, maybe a bench or a planter...
Cleaned up around the inner LH wing and A post, getting the remaining pieces ground off. A post needs a small patch but is good otherwise, door jam panel also looks ok once cleaned. There was a lot of brazing around front part of the doorstep panel, would it have been like that from factory?
Wire brushed around the number a bit more today and revealed it was 8 not 6. So 470383 - suggests it's 03/1983 build date of shell. 47 part is a mystery, maybe production line or operator number?
#99
Posted 23 January 2021 - 06:24 PM
#100
Posted 23 January 2021 - 06:34 PM
Do you mean brazing like this?
https://www.theminif...road/?p=3628024
There were a lot from factory, I have seen them there, A-panel to windscreen surround, in the gutter corners, door step to rear quarter panel, rear quarter to rear panel.
My car is pretty original (had a not-so-bad front crash).
Please see from page 3 in my project, you'll spot them.
I cannot remember of such a number stamped in the inner wing. It was pretty bad corroded too.
Ohh, and I should update my topic with the only thing I have done to it. Buying spares...
#101
Posted 23 January 2021 - 07:42 PM
Yes brazing like that, the RH door step was already replaced before so no brazing there.
#102
Posted 06 February 2021 - 07:12 PM
Took off the scuttle panel to allow me to finish removing the last parts of inner wing.
Offered the new inner wing up, bolted it in at the door hinge panel, then set about trying to make it fit. There was a small captive nut above the shock mount, maybe for charcoal canister in later models? Ground it down flush as it was fouling in the cross-member..
Tried fitting up the rest of the front panels, a fair bit of fettling needed to get these into the correct locations..
Hopefully get a bit more done tomorrow if the weather is good..
#103
Posted 10 February 2021 - 03:43 PM
Ordered a new scuttle panel to replace the old one I cut off, its rusty both ends and some of the gutter is missing. Planning on cutting out the VIN stamp and welding it onto new one, then blanking off the LHD wiper holes.
Also ordered another radius arm bearing, to replace the one I damaged, at least then I can get that finished.
Will be interesting to see what changes there will be to packages from minispares, what import tax and duty will have to be paid
#104
Posted 10 February 2021 - 03:59 PM
You could turn that old front end into a BBQ or a fridge, I knocked this together a few years ago and it did a surprisingly good job at keeping my beers cool
#105
Posted 28 February 2021 - 08:34 PM
My teardrop parts no longer have the rubber on them, but I did buy a poly fitting kit, do I just use the small bushings from that directly on the teardrop part?
