looking good!
1983 Mini City
#526
Posted 02 May 2024 - 09:34 PM
#527
Posted 03 May 2024 - 06:09 PM
Also got the fuel gauge working, had knocked out the power from the voltage stabiliser.
Added a high-level brake light, 3d printed a segmented holder that slips up underneath the window seal, wrapped in loom fabric tape to allow it to retain some flexibility.
#528
Posted 03 May 2024 - 08:31 PM
Hadn't noticed the 2 missing bits earlier, I hadn't been overly cautious with trial fitting it previously, so may have over-flexed it at those points...
#529
Posted 04 May 2024 - 02:22 PM
Template, card, wrapped...
And fitted. Not too bad, can't see how actual bought ones would fit any better without destroying them during fitting....
#530
Posted 04 May 2024 - 03:57 PM
Posted 04 May 2024 - 04:04 PM
Managed to fit my bought ones without destroying them. They've been removed and refitted on at least one occasion too.
I think it's due to me having the top padded dash rail and the centre clocks...
#532
Posted 06 May 2024 - 09:30 AM
Whole thread is great. Good job 👍
#533
Posted 06 May 2024 - 08:19 PM
Some photos from John Boland and Ben J Myers...
Then we went for a nice Sunday drive, about 150km in total, only hiccups were it got a bit hot as we pulled in to stop for food after a long climb up a steep hill, and got a noise coming from right rear wheel, sounds like a noisy tyre or possibly a wheel bearing...no sign of anything getting hot though...
#534
Posted 20 May 2024 - 09:46 PM
Changed out the sender GTR101 for a TT6811-01, as that's the one that's recommended by Merlin Motorsport where I bought the gauge (Smiths BT2240-00 with 50-90-140 markings)
Still reading higher than what it should be, when testing against 2 different temperature guns - both laser and infrared types
Onto the rumbling noise that appeared a few weeks ago. Checked rear wheel bearings for play, all seemed fine, then decided to whip off the passenger side one to check, clean and repack with fresh grease.
Cleaned them all down and noticed some minor scoring on the outer roller bearings, then cleaned outer races in the hub and felt a small imperfection, then seen the scoring around inside of it.
Knocked them out and put in a ball type bearing I picked up last week to have on hand, not ideal but it allows me to see if it resolves the noise while waiting for some genuine timkens as minispares no longer sell these non-genuine rear bearings...
#535
Posted 21 May 2024 - 08:19 PM
Also ordered another temp gauge and anti squeal shims to stop the brakes chirpping...
#536
Posted 24 May 2024 - 02:10 PM
Fantastic read, thanks.
Is your fan on the right way?
#537
Posted 24 May 2024 - 07:41 PM
Cheers.
Yes, fan is on the correct way, smooth side to the engine side
#538
Posted 01 June 2024 - 07:07 PM
Got my rear bearings replaced today, all sorted and no more noise.
Also added the anti squeak shims to the brake pads.
Fitted new alternator, much harder than I anticipated. New one hasn't got a threaded hole for the bolt near the tensioner, so had to rummage to find one!
Took it out for a spin, forgot about pushing the brake pistons back slightly, gave myself a brown trousers moment!
Edited by colinf1, 03 June 2024 - 08:49 AM.
#539
Posted 03 June 2024 - 09:03 AM
Took it for a longer spin yesterday, 115km/71miles total journey, taking a small car ferry on part of the route.
Anti squeek shims....it was like a bird tweeting most of the trip, must be a slight warp in the disc.
Temp gauge up at H at one point, a long climb uphill, most of the time it sat half way between N and H.
Its annoying because its taking some of the fun out of driving it, no cooland loss, no mayo under filler cap, no bubbling when cap is off radiatior.
Everything on the cooling side is new - apart from top and bottom hoses and thermostat (74c), it think I'll flush it all out again at the weekend.
#540
Posted 05 June 2024 - 06:53 PM
Sender tip placed into hot water, voltage set to 10v, gauge read 90c when water was 75c. Voltage set to 12v, gauge read 110c with water at 75c.
I've been getting readings of 75c - 85c using IR and Laser temperature guns so hopefully that means it's not overheating and just the gauge reading incorrectly.
At the weekend I'm going to let it get up to temperature and adjust the gauge to match what I'm getting on the laser/ir gun, hopefully!
