1983 Mini City
#301
Posted 25 November 2022 - 07:24 PM
I will dig my mirrors out of storage to make sure they marry up.
#302
Posted 27 November 2022 - 06:54 PM
This is new heritage sat in with no adjustments..
Looks good! It also shows everything on the front lines up as it should.
I then traced the profile of the edges of the new bonnet onto some wood, then lined up both bonnets to see how far away they were...1 was good on one side and way off on the other, mainly due to it getting squashed when the shell fell onto it when taking it for sandblasting 🤦♂️
Other bonnet was pretty close, just needed a small bit of adjustment that was caused by a split on both sides. Once that was welded up it held its shape nicely.
Spent the guts of 5 hours getting the paint strip off the outer side, paint stripper only softened the top layer didn't penetrate into the multiple layers of primer below, so lots of scraping and sanding...then removed old moulding platform removed ready for new one to go on.
Gave it a quick coat of zinc primer and sat it back in place..
Also got the boot lid sorted, small repair to the frame and a few pin holes. Hinges got sandblasted during the week, small amount of pitting along the lower edge but in good shape otherwise. Could only find 2 of the studs but not sitting too badly.
Small rust hole to sort in the bonnet, then the new moulding platform to go on, along with the spring and pin and the spring loaded latch from the old bonnet to be transferred across, then it's ready for paint!
#303
Posted 27 November 2022 - 08:04 PM
That should be 100% welding completed, isn't it? ;)
#304
Posted 27 November 2022 - 09:55 PM
Thanks Victor, hopefully this will come in useful tomorrow.
Got the mirrors out, the holes are offset so unfortunately your measurements aren't suitable, but thanks for the effort you went to.
The mirrors are just a basic minispares set that have been painted, there in good condition so going to use them.
I'm going to offer them up, mark and drill to suit, then git the rivet nuts in and another job will be marked off the list!
#305
Posted 27 November 2022 - 10:37 PM
#307
Posted 28 November 2022 - 11:19 AM
just to be a little pedantic, re: mirror fixings
really the hole centres would be better measured as follows, due to the curvature of the door edge. or, confirm the vertical distance down to where you did measure it
if that makes sense
saying that the 55 is probably going to stay the same, it's the 70 I would be questioning
Edited by stuart bowes, 28 November 2022 - 11:20 AM.
#309
Posted 28 November 2022 - 08:34 PM
if that makes sense
Those holes look like they are for a MK3 and older Mini mirrors. Colin, yours is a MK4 and the holes are different. I can post a picture (and measurements from a MK4+ Heritage outer skin if that helps.
#310
Posted 28 November 2022 - 10:33 PM
That would be great Conor...
Spent this evening strenghting the pallet and securing the shell. 4 x M16 bolts into 2 pieces of 4*2 attached to the pallet should do it. Also added fixed wheels that will hopefully make it easier to get it loaded into van for journey to get painted...
Put the door latches and striker plates back on too, doors close quite nicely with a small amount of adjustment.
#312
Posted 29 November 2022 - 11:14 AM
#313
Posted 29 November 2022 - 09:46 PM
Bonnet pin and hook disassembled, cleaned and painted. Hopefully get the bonnet repaired tomorrow.
#314
Posted 30 November 2022 - 04:23 PM
Hi Colin,
Sorry I should have said that my car is a MK3, so the mirrors are different. Something I just learned by the way... ;)
Victor.
#315
Posted 01 December 2022 - 09:37 PM
Popped it back on, put the pin, hook and bonnet stay back in and tried on the grille, all holes seem to line up nicely.
That's it ready for prep and painting!
