it was getting a bit late to make noise.
I swear if anyone ever invents the silent grinder they'll be in the money lol
Posted 09 August 2022 - 10:11 PM
Posted 10 August 2022 - 08:18 AM
my tank has rot around the filler neck as well, is that common then
I was thinking ditch it and get a new one (of all the things it's best to just replace..) but have you seen the price, jeez
once you welded it up are you going to get it pressure tested or something, im thinking maybe if I do go down the repair route maybe it's one I should just get professionally done to be on the safe side. but in theory there's no reason I can't just weld it myself though right
As the rot was only around the filler neck, I was confident enough to do it myself, as fuel would be lower than this point so wouldn't need to pressure test it. I also cut the neck off above the existing weld bead, then welded the new neck piece to that weld bead reducing any chance of blowing through, the pipe was also a bit heavier at ~2mm wall thickness vs the 0.8mm of the old one, which helped too.
I guess any water that gets in around the rubber seal will sit under the foam ring that goes around the neck, causing the rot to start there.
Posted 12 August 2022 - 06:34 PM
Posted 14 August 2022 - 05:30 PM
Edited by colinf1, 14 August 2022 - 05:34 PM.
Posted 14 August 2022 - 06:24 PM
Posted 14 August 2022 - 06:50 PM
Looking good Colin. Have you tried the rear subframe? When I did my boot floor it needed a bit of adjusting.
Cheers.
Victor.
Posted 14 August 2022 - 07:17 PM
Posted 15 August 2022 - 09:32 PM
Posted 16 August 2022 - 04:41 PM
Posted 17 August 2022 - 05:23 PM
Posted 19 August 2022 - 04:16 PM
Posted 21 August 2022 - 03:38 PM
Posted 23 August 2022 - 06:20 PM
Posted 06 September 2022 - 08:34 PM
Posted 10 September 2022 - 07:25 PM
