Yellow A Plus Engine Paint Colour Code
17 replies to this topic
#1 Avtovaz
Avtovaz
  • 1,265 posts
Posted 14 June 2020 - 07:29 PM
is there a colour name or code for the engine paint on a a-plus engine, if i phone paint suplier tomorrow they will ask for a code or name. thanks
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 June 2020 - 08:16 PM
<p>I looked at this before and think it's pretty close.</p>
<p>&nbsp;</p>
<p>https://www.plminish...High_Temp_.html</p>
<p>&nbsp;</p>
<p>No code but it can be purchased from them.</p>
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 June 2020 - 08:21 PM
<p>A quick squint online shows this</p>
<p>&nbsp;</p>
<p>http://www.somerford...oducts_id=15378</p>
<p>&nbsp;</p>
<p>Which they list as yellow for a+ engines</p>
<p>Looks the same as the stuff in the first link too so could well be the correct stuff?</p>
<p>&nbsp;</p>
#4 Avtovaz
Avtovaz
  • 1,265 posts
Posted 14 June 2020 - 08:24 PM
thanks mate you summerford link dosnt work but i found it on there, i never thought of them and for 500ml is just shy of £13... Ill phone them tomorrow and order it!
thankyou AGAIN!
EDIT, i take it i can spay this on if i add a bit of thinners in it?
Edited by Avtovaz, 14 June 2020 - 08:25 PM.
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 June 2020 - 10:44 PM
You can spray it but it's alkyd based so you would need to use acetone and not thinners.
I think the recoat times are quite long too. Something like 24 hours between coats from memory.
Might be as well to brush it on straight from the tin.
#6 Avtovaz
Avtovaz
  • 1,265 posts
Posted 15 June 2020 - 06:50 PM
ive seen people paint engines and they look hand painted, thats why i wanted to spray it on. But maybe just paint in on and hope for the best... thanks again!
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 June 2020 - 07:30 PM
I think the biggest problem with brush painting engines is that the job is usually rushed and too much paint is applied in each coat.
You can't expect to get a decent full coat with one application. It needs to be built up gradually in thin coats observing the correct recoat times and then you will get a quality finish.
If you are set on spraying it on, you might be better off finding an alternative paint. Is there any of the original paint remaining on the engine that you could use to get a colour match? Failing that, you could always hand paint a scrap of metal in the somerford paint and then take it in to be matched at a paint supplier.
Ben
#8 Avtovaz
Avtovaz
  • 1,265 posts
Posted 15 June 2020 - 07:48 PM
yes the head and block still have the original paint on them. But as you say, if i do gradual coats, maybe itll look good. I think part of the engines ive seen teh paint looks far too thick, and that is why. I think also, when people paint the ally parts, makes a difference too, i want it to look factory.
thanks again
#9 Avtovaz
Avtovaz
  • 1,265 posts
Posted 02 July 2020 - 08:07 PM
thanks again ben, the paint came today from summerford along with a big order of parts to rebuild the engine. I was quite surprised as the yellow is more like the yellow i remember with mixed with dirty 20/50 already in it! It seems a very strange choice of colour by austin rover !!! thanks though
#10 cooperd70
cooperd70
  • 730 posts
Posted 13 July 2020 - 02:14 PM
When you get a chance to paint up the block with the paint from Somerford Mini I'd appreciate a photo...I have photos of the engine bay of my car when it was new in 1990, but the film stock/camera/photo processing wasn't the same back then as it is now so I'm unsure of colour accuracy. However, how you have described the paint sounds the same as how I'd describe my engines colour when the car was new ?
#11 Avtovaz
Avtovaz
  • 1,265 posts
Posted 13 July 2020 - 07:58 PM
well i have painted it already!
Now, this is strange, when i post the pic, it look bright yellow but it isnt
In real life it looks like the older paint on the head, and the head looks darker.
The engine looks like how i remember it to be, not bright in your face yellow but like some left over yellow from the army they used in desert war! On my lada i had the block was in russian army grey lol
HTH.
#12 cooperd70
cooperd70
  • 730 posts
Posted 13 July 2020 - 08:01 PM
Thanks....yes in the photo I have (from 1990) the yellow is more a darkish mustardy yellow and not bright yellow. Maybe your digital camera/phone is compensating for the odd colour...think that this is the paint I will need as well.
Cheers ?
#13 Avtovaz
Avtovaz
  • 1,265 posts
Posted 13 July 2020 - 08:04 PM
look at the tin on the right hand side of the pic, its like that. It is the right stuff defo, and if you do an order from summerford for other bits the postage isnt that much.
#14 cooperd70
cooperd70
  • 730 posts
Posted 14 July 2020 - 05:40 AM
#15 gaspen
gaspen
  • 976 posts
Posted 17 June 2023 - 05:55 AM
Hello
Could somebody help me the RED color code for the A+ 1275 engine ?
