OK so the knocking from my wheel well is a worn Hardy Spicer joint and a buggered wheel bearing on the 72 clubman.
I have never replaced The Hardy Spicer joint before so any advice would be helpfull.
But when I am doing this is there any thing else I should be doing?
I plan on replacing the suspension and bushes, all the wheel bearings and refurbish the wheels and new tyres, new cv boots on the wheels, new steering rack gaiters.
Is there anything else I could be doing down there because I would like to do the job and it to be finished once and for all.
We also found some serious rust spots/holes so a bit of welding and body work is going to be needed, and a full respray will be on the cards as well.
Seems I have my work cut out for me eh!
