1980 Mini Van
18 replies to this topic
#1 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 04 June 2020 - 08:33 PM
Hi all,
After an offer came up I couldn't refuse, i finally picked up a Van! For those of you that remember the Magnetagz van, then yep, this is where it is now! It's a bit rough around the edges, needs some panels re-alligning and some rust catered for, but overall, it's in great condition! Plan is to keep it the same colour overall, however the roof will be sprayed black once the LED lights come off. Lots of wiring inside that is irrelevant and some that needs tidying up!
On the drive home it absolutely tipped it down, but enjoyed every minute of it! Its the first Mini i've owned on 10s and love the ride! I'll keep this up to date where i can, but i intend to document it on my youtube channel mainly!
Started ripping out the interior
That gap tho..
#2 nicklouse
  • 18,593 posts
Posted 04 June 2020 - 08:39 PM
Can’t wait to see what you get up to with this. And yes the 10s. What do we keep saying.
#3 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 05 June 2020 - 07:36 AM
Didn't i read somewhere that you already have a Mini you're meant to be working on? :P
Finish that one before you start ripping into this one, you know you're a perfectionist & if you even start to touch this you'll end up with 2 Minis neither of which you can drive for some time.
#4 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 05 June 2020 - 07:20 PM
Ha! Felix is up and running! The van will keep me busy. I get bored easily ;)
#5 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 06 June 2020 - 12:39 PM
Spent all yesterday on the car. Stripped the rear out and managed to remove miles of spare wiring. The washer pump now works and i have headlight flast! Removed all the sound deadening, gave it a full clean and put on a set of white wall trims :shades:
#6 ADRay
ADRay
  • 97 posts
Posted 06 June 2020 - 01:40 PM
I like it!
#7 bpirie1000
bpirie1000
  • Area Managers
  • 2,346 posts
  • Local Club: Amoc
Posted 06 June 2020 - 03:25 PM
Love it.. Van'tastic...
#8 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 08 June 2020 - 09:40 AM
Looks great Steve!! I do love a van. Wish I'd bought one before the prices went a bit nuts.
I expect you're going to lose those roof lights, and maybe the side repeaters too? Clean/classic look, or do you have something else planned?
#9 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 08 June 2020 - 05:36 PM
Thanks chap!
The roof lights are gone.. updates to come! Keeping the side repeaters as I actually quite like them :shifty:
#10 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 07 July 2020 - 03:44 PM
Fair bit of an update!
Gave the Van a machine polish and replaced the roof lights for nice little grommets (temporary)
Really pleased with the shine
THEN the wheels decided to eject the trims off at speed, so finally ditched them and tried my hand at Mr Whitewheels paint
Can't forget the other car!
...and it came off :(
So took the plunge to have the wheels powdercoated and taken directly to Mr Whitewheels in Stafford and Ant there did a cracking job!!
Sound deadening time!
I then had an overheating issue. After pulling the head apart it had melted a valve and the seat was cracked. Its what happens when you run a leaded head on unleaded. Engine got super hot and took the crappy headgasket too. What I also found was the bypass valve was blocked.
Thanks to Adam Campion of youtube fame for a replacement, unleaded!, cylinder head! On with a composite gasket.
New plates today :)
#11 Globule
Globule
  • 1,134 posts
Posted 07 July 2020 - 05:43 PM
Looking good, nasty head crack though! Have you driven it since installing the sound deadening? What is the bracket on the rear floor for, is that for the jack?
#12 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 07 July 2020 - 05:55 PM
Yep, as my late father used to say, if you're going to break it, do it in style! I have, it has moved the higher frequencies into the mid range where the closed cell foam will get it more efficiently. The bracket is for the wheel brace for the spare wheel mounts to.
#13 jamesquintin
jamesquintin
  • 1,017 posts
Posted 28 July 2020 - 06:55 PM
How many Dodo sheets did you use..? Just about to do my MPI and could do with some :)
Q
#14 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 28 July 2020 - 08:01 PM
Q
On the MPi i used 25. On the van, i ended up using all 40.
#15 Van13
Van13
  • 314 posts
  • Local Club: Unknown
Posted 02 August 2020 - 06:30 PM
I use dynamat it makes a massive difference to the interior of a van,vans look cool but if you don’t sound deaden them there noisy inside
