Electronic Ignition With Non Resistor Spark Plugs, Champion N9Yc
Posted 31 May 2020 - 11:41 AM
Posted 31 May 2020 - 12:02 PM
Posted 31 May 2020 - 12:27 PM
Resistor plugs would be to reduce EMF interference that could mess with the electronic and are also likely to be stronger with electronic switching. Your plugs leads will also add resistance. Just try 'em, if you get misfires or loads of crackling on your radio (or neighbour's telly) you can switch back.
Posted 31 May 2020 - 06:15 PM
Posted 01 June 2020 - 06:50 AM
i have a 998 with electric ignition. Still running BP6ES. No issues. I have changed the gap to 35 thou.
Posted 01 June 2020 - 08:42 AM
I'm sure I also needed resistor plug leads on one of my minis too as I was getting the electrical signal whine through the sound system.
Edited by cal844, 01 June 2020 - 08:43 AM.
