Forgot about this thread, got lots of updates so will get to work updating this!
Nut & Bolt Rebuild With Added Type-R
#46
Posted 08 April 2022 - 04:25 AM
#47
Posted 09 April 2022 - 09:00 PM
Right some photos of the fabrication work now I can post again!
First they modified the inlet manifold to fit against the bulkhead. The runners are cut and re-welded at an angle. This is done so we don't have to make any modifications to the bulkhead itself, something I wanted to avoid.
Radiator measured up and made. This is the biggest we could fit without causing clearance issues with the wheel/subframe. It looks small but the thick core actually gives it a larger capacity than a stock Civic radiator so should perform well. The bonnet will have holes in to aid airflow to it as well.
Offered up!
Header tank made up and a SPAL fan fitted, some plumbing in also done
Manifold all made up, this was such a tight fit and only has about 2mm of clearance. Who's idea was it to try and do this with a completely standard body shell?
Gear selector shortened and bolted up, all gears select beautifully, you wouln't know you're not sat in an EK9!
Had to clearance the subframe in the process, a shame we had to do this as the subframe was expensive and is designed for this setup but there we go.
Onto the exhaust. I went with a single box setup with a 200 cell HJS cat. We don't need a cat by law on this setup but seemed a good idea to keep noise and smell down as much as possible.
Few photos of the finished product after I collected it
We are so so close to getting this on the road now, next priorities are getting the alternator fitted as well as the driveshafts. Then I'm going to concentrate on wiring and see what happens when I turn the key! Once I've got it running, it's just a case of fitting the interior and some finishing touches and we can start using it!
Edited by Harry L, 09 April 2022 - 09:28 PM.
#48
Posted 09 April 2022 - 09:15 PM
Quick trip up to Birmingham to see JB Auto Trimmings to pick up something rather special
They've done an absolutely amazing job, I absolutely cannot wait to get it all fitted, it will compliment the blue exterior so well. I didn't have any interior at all, so they supplied the seats and trimmed them in tan leather with twin Bentley style diamond stitching.
#49
Posted 10 April 2022 - 09:00 AM
Very close now
#50
Posted 28 April 2022 - 09:30 PM
Some lovely fabrication work there - and a great interior - bet you can't wait to drive it!
#51
Posted 31 December 2022 - 11:55 AM
Realised I haven't updated this in forever, but the car is now running! Lots of progress has been made including fitting the alternator and driveshafts, neither of which are easy jobs and took a lot of time and tested my patience right to the limit!
Couple of Youtube videos linked below of its first start. At first, the idle was very erratic which we quickly diagnosed as an air leak at the inlet manifold. After tightening up the inlet manifold, the car now idles perfectly and sounds great!
First ever start - https://youtube.com/...Q?feature=share
Revving video - https://youtube.com/...s?feature=share
Idling perfectly once fixed - https://youtube.com/...8?feature=share
Going to get the body loom wired in this week and get the interior fitted, then it's just a few small jobs and it'll be ready to start driving
Edited by Harry L, 31 December 2022 - 11:57 AM.
#52
Posted 31 December 2022 - 12:50 PM
I have to say i was never really a fan of these conversions (each to their own i know) but i have to say these engines have so much potential its mad and your set up looks the mutts nuts.
More of a convert now especially when watching and following PFI Speed and BoostedBoiz on Youtube and seeing what can be done (and cant be in certain cirumstances)
Honda have built some engines over the years that take some serious abuse and power outputs especially if you put one of the little (or not so little) spiny sucky whistling things on (turbo or supercharger) Power outputs surpassing with ease most common sports cars (Porsche Ferrari etc) and big V8. Honda K20 and K24 engines with a turbo on, springs and retainers can see in excess of 600+ bhp with a Hondata ecu or Fueltech ecu. And its reliable power as well. Put a bit more effort into the engine build and away you go eclipsing power outputs that most of us would have thought crazy to achieve. What a scene to be involved in.
#53
Posted 31 December 2022 - 01:13 PM
I too was never really into engine swapped Minis at all, always thought if you want a Honda powered car then just buy a Civic I even had machined and rebuilt a nice MG Metro 1275 engine which was ready to fit when I just had this horrible urge to fit a VTEC engine. I've never even driven an engine swapped Mini so this is a massive gamble that might go very wrong once I actually get behind the wheel!
I have kept as much of the car as original as I can, no bulkhead mods, intact standard front end and still on proper cone suspension as I want it to feel as 'Mini' as it possibly can, albeit with a completely different character under the bonnet.
#54
Posted 20 January 2023 - 07:42 PM
I'm not being very good at this build thread, thought I'd post a few photos of where we are up to now.
Fitted the washer tank under the NSF wing, will have to wait and see if this has clearance issues with the tyre under compression but it looks okay
This is how the engine bay is looking now the alternator and air filter is fitted, currently remaking the loom and it can be fitted permenently
Rear brake lines made up
Rear brake lines being fitted, I'm not going to show you them as it's a bloody mess
Garage doggo
Driveshafts built up and fitted, Japanese maintenance free balljoints waiting to go on
Rear foglight and bumper fitted
Front bumper and grille fitted
ONTO THE INTERIOR!
Parcel shelf mounted third brake light
Audio cables and front to rear loom fitted ready for the carpet
This is such a stressful job! I'm using the Optimise Automotive carpet which has about 20mm of foam on the backing so really difficult to get it in position, but the end result is lovely
Seats fitted
Very happy with my choice of a suede headliner!
Rear speakers fitted
And some doorcards
Was quite amused that the tyre of my daily is taller than the bonnet of the Mini!
Drove it down the drive to get some photos of it out in the open
Gave it a clean, and this is where we are at now
That's us up to date now, got a weekend of progress ahead where we will hopefully have the engine loom finished and wired in for good, then the clutch needs more bleeding and we can take it for a little shakedown!
The next big thing to tackle is the wiring, we are going to wire the body loom from scratch as I've removed all traces of the original Mini wiring, then I'm going to make a dashboard we will be ready to finish all the little bits and pieces before it's ready for the road, it's going to be a fun summer of driving this thing
#55
Posted 20 January 2023 - 08:11 PM
#56
Posted 20 January 2023 - 08:26 PM
very nice build, i started my 10 years ago still not finished it yet. Have you driven it yet?, how do you find it to drive?.
#57
Posted 21 January 2023 - 10:48 AM
I've driven it about 10 meters to the end of my drive and turned it round! Here's a video of its first ever drive, this is when it had no throttle cable connected and only half a clutch
https://www.youtube....rts/aTKDhI-1O84
One thing I noticed when I turned it round is the wheels catch on the arches big time, going to have to clearance it a bit but first I'm going to get the right height set correctly and also get an alignment as the wheels are all over the place!
A set of Carbon Weezel arches will then be the very last thing once I'm happy with the right height and alignment.
#58
Posted 18 January 2024 - 04:39 PM
Another long time, no update! Things have been progressing with this and I'm much better at keeping my Instagram updated than this thread.
Firstly, finished building the engine loom, wrapped it all in loom tape and fitted it. This is pretty much the finished engine bay now.
1.jpeg 53.01K
0 downloads
2.jpeg 106.28K
1 downloads
Once this was all tested and confirmed everything engine wise worked properly, we started on the body loom.
4.jpeg 96.87K
1 downloads
3.jpeg 78.49K
1 downloads
15.jpeg 35.73K
0 downloads
This is a fully bespoke wiring loom designed just for this car. I was originally going to use a Mini loom, but after seeing how badly it is fused and the amount of wasted cable, I decided to build one from scratch. Everything that draws a significant amount of current is protected by a relay and no wire isn't fused! I've used all red or black 2mm or 1mm thin wall cable with two fuseboxes.
I'm almost complete with this now, just a few more circuits (horn, HRW and fog light) and it'll be ready for taping up.
#59
Posted 18 January 2024 - 04:43 PM
Next up, the arches were bought and fitted. The wings needed a lot trimming off to stop the clearance issues.
9.jpeg 84.2K
0 downloads
10.jpeg 59.57K
0 downloads
Trimmed the arches as well to reduce their width.
12.jpeg 58.62K
0 downloads
11.jpeg 53.5K
0 downloads
Cut a couple of holes in the bonnet and fitted a bonnet lift kit from DSN, should help with airflow and keep the temps down in the summer
14.jpeg 87.14K
0 downloads
17.jpeg 60.63K
0 downloads
#60
Posted 18 January 2024 - 04:46 PM
Time for some woodwork, built a subwoofer enclosure for a 10" sub in the boot.
5.jpeg 41.23K
0 downloads
Dashboard starting to take shape
6.jpeg 53.63K
0 downloads
26.jpeg 41.09K
0 downloads
29.jpeg 86.92K
0 downloads
30.jpeg 85.32K
0 downloads
31.jpeg 55.28K
0 downloads
32.jpeg 88.26K
0 downloads
Also wrapped the top dash rail in foamed backed Alcantara to match the dash
23.jpeg 102.01K
0 downloads
