Cam cover restored in the original crinkle red with polished lettering
Painted
Posted 29 May 2020 - 10:41 PM
Painted
Posted 29 May 2020 - 10:47 PM
Got some engine work done this week.
Posted 29 May 2020 - 10:54 PM
Posted 29 May 2020 - 11:01 PM
Posted 30 May 2020 - 08:19 AM
That's going to be one fast mini Harry, I came across a guy who worked at Unipart in Nottingham who did the very same conversion he said "it was mental to drive"
Posted 30 May 2020 - 08:22 AM
How are you going to set up the drive shafts for this ?
Posted 30 May 2020 - 09:36 AM
You said the allspeed CVs are the known weakness for a mini? Have they failed before?
Conversion it looking good! Your suspension will settle and lower the car over the next week weeks. Get the engine in and re-adjust after as it'll go everywhere
Thanks for getting good detailed pics up too! I have a new project coming and want to use the basic allspeed subframe for it, so seeing how much room there is in the engine bay really helps!!
Posted 30 May 2020 - 10:13 AM
I'll be using the Allspeed HD driveshafts, keeping the whole thing as bolt-in as possible.
Posted 30 May 2020 - 10:16 AM
Sorry, what I meant by that is the stock Mini CVs are the weak point, the Allspeed ones have 25 teeth increasing the driveshaft CSA (stock Mini ones are 19t IIRC).
Thanks! Yeah expecting the cones to settle a lot as they're new and the car doesn't have any weight in it at the moment.
Posted 30 May 2020 - 10:17 AM
It will be really interesting to see how it drives, I've never driven a 16v Mini so really don't know what to expect!
Posted 30 May 2020 - 03:14 PM
Excellent will continue to follow your post
Posted 30 January 2021 - 02:40 PM
Update time! It has been a while, but since my last update I have moved house and now have a garage, spent a few months getting that into a useable workshop and other house stuff got in the way as usual.
Started with wiring, new LED headlights fitted
And all working, the headlights have LED indicators built in, so the glass indicators in the body are wired through a resistor as USDM style DRLs.
Posted 30 January 2021 - 02:43 PM
New RMS and clutch fitted to the engine
I also got the gearbox back from BK Transmissions after a full rebuild with new input bearing, 4.0 final drive and LS long 5th gear
New cambelt, tensioner and waterpump
And sump fitted with new gasket and stainless hardware - these always rust and turn into nothing so a good bit of futureproofing
Posted 30 January 2021 - 03:51 PM
Had to modify the engine mounts that the Allspeed frame comes with as he put no thought into people wanting to run poly engine mounts.
Cut out the inner strengthening bits, my fabricator will add more supports to the outside when it goes there for the other bits.
Mount now fits!
Wiring is still in progress
Posted 30 January 2021 - 03:52 PM
