Spi Fuel Hoses And Hard Pipe Connection
2 replies to this topic
#1 Wazzah
Wazzah
  • 142 posts
Posted 27 May 2020 - 01:00 AM
Dear Forum,
I have a query regarding the engine bay connections between the rubber fuel hoses and the hard lines back to the tank.
I need to replace my rubber hoses and there appears to be 2 connectors ( to and from the tank) that may be a click fit adaptor.
They seem to swivel on the hard pipe.
GM have a factory quick connector and i'm wondering if these are the same.
I realise the connections on the throttle body hard pipes are crimped.
Does anyone have any details about these connections?
Kind Regards
Waz
#2 MatthewsDad
MatthewsDad
  • 812 posts
Posted 27 May 2020 - 11:42 AM
It's just 8mm injection fuel hose pushed onto the hard fuel lines (supply and return) and kept in place with a hose clip. Or are you referring to clips to mount the fuel pipes running below the floor from the tank to the engine bay? I have photos of the connections in the engine bay if this helps.
#3 humph
humph
    How bad can it Be?
  • 1,096 posts
Posted 27 May 2020 - 01:05 PM
As per Matthewsdad's post above, mine are just the standard fuel hose pushed on to the hard pipes and clamped.  You can see the end that joins the hard pipe to the throttle body on mine in the centre of the picture below, the other end where they join the hard pipes under the car are the same.
31238353727_4a924bbd2a_b.jpgCoolant temp & O2 sensors 2018 by Humph, on Flickr
Hose clamps are these type or the ones with the worm drive
38b51f6dc167173329ea5223e682de96_Spring-
Edited by humph, 27 May 2020 - 01:05 PM.
