Van Wiring Loom Routing
7 replies to this topic
#1 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 21 May 2020 - 07:11 PM
Has anyone got any pictures of the routing of the van rear loom?
Or a description of.which route the loom should follow from engine bay to rear lights
Thanks in advance
#2 Steve220
Steve220
  • 4,994 posts
  • Local Club: BMC
Posted 21 May 2020 - 07:23 PM
It comes through the fire wall at the centre just behind the binacle. Once inside (when sitting in the car, it splits both left and right. Right goes to the steering column (RHD), there's a part that goes to the centre switches, then the rest goes left where it couples to the rear loom. The rear loom goes up the A pillar, over the passenger side door behind the headlining, down the seam and down next to the N/S rear panel.
#3 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 21 May 2020 - 07:29 PM
Ok so when it goes through the channel above the passengers door it then just continues along the roof until it reaches the rear corner(beside left rear door?)
#4 REVVIT
REVVIT
  • 341 posts
Posted 21 May 2020 - 07:44 PM
Nope just behind the B post there is a strengthening panel from the B post to the side panel..the loom passes through that gap down to where it meets the load bed..then it travels to the rear light cluster passing over the wheel arch..You should have two P shaped panels which hold the loom down to the floor..
#5 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 21 May 2020 - 08:13 PM
Steve220 & revvit thankyou for your help, I have it roughed in now. Haven't got any metal 'p' panels unfortunately but I'm sure I will.manage to figure something out
Thanks again
Edited by owenlcr, 21 May 2020 - 09:08 PM.
#6 KTS
KTS
  • 2,392 posts
Posted 21 May 2020 - 09:29 PM
..the final section : drop down through the floor below the nearside light cluster, back out though the valance closing panel and run across the back of the car above the fuel tank and then back up through the floor to the offside lights
Note : the fuel tanks needs to have been removed
Edited by KTS, 21 May 2020 - 09:31 PM.
#7 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 22 May 2020 - 06:24 AM
Superb thanks alot
#8 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 22 May 2020 - 12:42 PM
M-machine sell the 3 part kit so will get that ordered to make it 100%.
