1972 Mini Van @classic And Sport
7 replies to this topic
#1 Classic & Sport
Classic & Sport
  • 33 posts
Posted 21 May 2020 - 10:05 AM
Starting this thread as a bookmark really, not ready to start on it for a few weeks but i have this 1972 van in for a full restoration
Its a mess (aren't they all) and comes firmly from the era of pop rivet and self tapper "repairs"
few goodies in the back, new rear subframe, another pair of rear doors but not much to get excited about!
Plans? unsure at the moment, low, 10" minilights, no arches, smoke grey with black roof is a possibility, being built to sell rather than keep so need to keep its appeal wide
Ryan
#2 GraemeC
GraemeC
  • 7,476 posts
Posted 21 May 2020 - 01:41 PM
Looks like its been rescued from a scrap yard once?
#3 Classic & Sport
Classic & Sport
  • 33 posts
Posted 21 May 2020 - 01:43 PM
Definitely been lifted with a strap at some point, when or why I don't know
#4 Classic & Sport
Classic & Sport
  • 33 posts
Posted 26 September 2023 - 10:45 AM
Catch up on this one....
was intending to restore this myself but it ended up being sold to a customer who then asked me to restore it for them so here goes, will try and keep it in order and with descriptions as much as possible but lots of pictures so might end up a photo dump at the end
start of stripdown and assessment, front end was held on by 4 self tappers!
Floors were in a bad way, not even worth trying to rescue them so full floors from m - machine ordered, customer took the opportunity to go with a later rod change tunnel at the same time to enable a later engine & box to be fitted instead of the magic wand it came with
floors were on their way so started to remove the old
I try and remove as little as possible when doing any panel replacement so I have more references for lining up the new panels so I started on the load bed, however in this case it was quite clear that there was so little strength left in the shell it would be quicker and safer to weld everything up on the jig and just go for it
so this happened....
new floors
epoxy primed in the box sections and hard to reach once fitted areas, also centre support for load floor and spare wheel bracket salvaged from old floor and fitted
welding the load floor and front floor together
Uniting the remains of the old shell with the new floor, rear quarters, doorsteps etc were all scrap and due to be replaced but were prepped in the same way as if I was reusing, i.e all traces of any adjoining panel removed to make lining up easier, along with lots of measurments! unfortunately the drivers side had been badly botched in the past but thankfully passenger side was original so I had something to compare too, along with another van shell in the workshop at the same time
all went together smoothly, next up was doorstep repairs so I could begin to start resting the shells weight on the new floor, toeboard was also welded to upper bulkhead at this point and rear doorposts temporarily tack welded into roughly the right place
rear arches next, again, rear quarters were trimmed back as if they were was being reused just to make alignment easier and more accurate, what was left of them at least
much the same on the other side, seem to be missing the photos for that
quarters next, not fully welded on the rear corners as repairs still needed in this area
and bringing us up to date is front inner wings and inner door post repairs
and as it currently sits, still to do, rear corner post repairs, line up rear doors, replace roofskin, complete repair / reskin doors, front panels
some misc bits and pieces
Edited by Classic & Sport, 26 September 2023 - 10:47 AM.
#5 Retro_10s
Retro_10s
    Moderator
  • 10,190 posts
Posted 26 September 2023 - 02:53 PM
ooooff this is a great rescue, just goes to show that often the Belts and Braces approach, whilst bigger, can make the job easier! Others would've scrapped that so I'm really glad to see it's being saved with such high quality work!
Edited by Retro_10s, 26 September 2023 - 02:53 PM.
#6 Classic & Sport
Classic & Sport
  • 33 posts
Posted 26 September 2023 - 03:05 PM
Thank you, appreciate it, would have been impossible without the jig
#7 Steam
Steam
  • 965 posts
  • Local Club: Victorian Mini Club
Posted 27 September 2023 - 03:10 AM
I do not think any mini should be scrapped these days, they are all worth the effort.
Nice to see someone in my old stomping ground doing mini repairs.
Where were you in the 80's when I needed you. LOL. You could have fixed my vans bodywork. :-)
#8 Yoda74
Yoda74
  • 58 posts
Posted 06 October 2023 - 07:52 AM
Great respect for this restoration, it was more hole than steel.
Many people would have scrapped it.
Nice work!!
