1976 Austin Mini
67 replies to this topic
#61 bajean
bajean
  • 124 posts
  • Local Club: Malta Mini Owners Club
Posted 06 November 2023 - 06:52 AM
For anyone wondering this is my setup on the weber. Its a 45 DCOE on a 2.75” maniflow manifold running the following jetting :
Choke - 36mm
Main jet - 150
Air corr - 200
Em tube - F2
Pump jet - 45
Idle - 50F13
Edited by bajean, 01 November 2024 - 03:21 PM.
#62 bajean
bajean
  • 124 posts
Posted 03 December 2023 - 05:09 PM
More changes to the mini :
  • 5x10 minilites
  • changed the rear slave cylinder from .75" to 0.5" bore ( as on hard braking the rear would always want to swing out )
  • changed the brake pads to a set of mintex 1144 ( bit of an upgrade from the ebc greenstuff, they are quite a bit better than the ebc"s especially after they've got some heat in them )
Now waiting for the roll cage to arrive ( got a full safety devices cage on the way ) as well as a set of takata harnesses.
#63 bajean
bajean
  • 124 posts
Posted 20 January 2024 - 10:45 AM
Finally installed the full 6 point safety devices cage with the harness bar and takata 4 point harnesses ( with ASM - anti submarining ). Still need to give it a good clean reinstall the carpets and passenger seat and door bars. Another big job done from the never ending list. The car also feels so much tighter and responsive than before handling wise !
  • Attached File  1.jpg   49.15K   5 downloads
  • Attached File  2.jpg   41.84K   5 downloads
  • Attached File  3.jpg   42.43K   4 downloads
#64 duds100
duds100
  • 231 posts
Posted 24 January 2024 - 06:00 AM
Looking awesome. Great job!
#65 bajean
bajean
  • 124 posts
Posted 01 September 2024 - 02:02 PM
Haven't posted in while as i have just been enjoying the mini as is. VRT ( MOT equivalent ) was due this year so sorted that out last month, passed with flying colours, the tester kept on mentioning how well the engine ran and how little emissions it produced .....
Also yesterday i finally installed my homemade cold air intake ( designed on fusion 360 and than 3d printed using ASA filament for anyone wondering ). Now the weber can actually get some fresh air rather than just hot air.
More mods hopefully coming soon....
Edited by bajean, 02 September 2024 - 05:42 AM.
#66 bajean
bajean
  • 124 posts
Posted 02 December 2024 - 05:41 PM
Finally built my dream setup - split 45 webers. having some problems with setup tho seems like it needs re-jetting big time. I also plumbed in an accusump for pre oiling and surge protection  ( never had any issues but an extra precaution )
Edited by bajean, 03 January 2025 - 04:10 PM.
#67 bajean
bajean
  • 124 posts
Posted 05 December 2024 - 09:45 AM
https://www.youtube....rts/UtQ9IKUC8E0 - video of it running
Finally sorted it out, idles at 14.8-15 afr. Still need to go for a proper drive and see how it performs under load but looking good so far.
#68 bajean
bajean
  • 124 posts
Posted 03 January 2025 - 04:25 PM
For anyone wondering on the jetting I ended up going with.
36mm chokes
160 main jet
60f8 idle jets ( still need to play around with F13/4/2/5 to get a leaner AFR on low revs )
50 pump jets
200 air correctors
F2 Emulsion tubes
Its feeling really strong, pulls cleanly from around 2k all the way to 7k. It also feels like the power band comes on sooner in comparison to the single 45 and is also more responsive.
