1976 Austin Mini
#31
Posted 29 July 2022 - 07:48 AM
#32
Posted 29 July 2022 - 07:56 AM
Posted 29 July 2022 - 08:09 AM
I started off by gapping the rings to 12thou ( put the ring in by hand and pushed it down with the piston ). Out of the box all the rings came in at 11 or 12 thou which was right within the spec i was aiming for. Having gapped all the rings I moved on to measuring bearing clearances on the mains with plastigauge ( which came in at 0.038mm ) and measured endfloat on the crank. Using a set of std thrust it had just 2 thou of endfloat which is a bit on the tight side. I then proceeded to lap in the thrust washers using 400 and 800 grit sandpaper and WD40 to get the endfloat to 4 thou.
Posted 29 July 2022 - 08:21 AM
Having done all the measurements it was time to build the engine for real. Started off by putting in the crank, applying a generous amount of assembly lube and torquing the mains to 63 ft/lb with arp lube. Checked the crank to see how it spins and all was good. Next came the followers and then the camshaft ( once again with a healthy amount of assembly lube ). Pistons where next, made sure to offset the rings, once again applied plenty of assembly lube to the rings and bores and slid them in. Then torqued the arp rod bolts to 30 ft/lb with the arp lube. Having torqued everything and checked everything multiple times turned the engine over a couple of times and all was good.
Edited by bajean, 30 August 2022 - 11:15 AM.
#35
Posted 29 July 2022 - 08:41 AM
Edited by bajean, 12 August 2022 - 06:31 AM.
#36
Posted 29 July 2022 - 08:46 AM
After that whole mess, I put in all the oil gallery plugs, core plugs KAD oil pump and a couple of other things. I then gave it a coat of paint. I then put in the MED billet filter housing, and prepared to dial in the cam, thats when i noticed i had forgotten to buy a new cam triangle ( the one in the picture is old and bent ), so i am now waiting for the new triangle to arrive aswell as some other goodies from MED.
Edited by bajean, 07 August 2022 - 04:00 PM.
#37
Posted 02 August 2022 - 07:46 AM
Yesterday was a good day in terms of progress. Dialed in the camshaft endfloat to 0.10mm ( had to skim the backend of the timing gear as i only had 0.05mm of endfloat ). Then went ahead and timed in the camshaft, this piper XT is supposed to be timed in at 107 degrees, after checking it three times in a row got it to 106.5 which is good in my book ( as the chain stretches it will get to 107 ).
Edited by bajean, 02 August 2022 - 12:29 PM.
#38
Posted 02 August 2022 - 07:55 AM
Having done all the precise and accurate stuff, all that remains are the easy bolt on parts. Next on the list was to insert the distributor shaft while I still had easy excess to make sure engine was at tdc and the alloy timing cover from MED. Next was the Rally spec head, MED steel pushrods and 1.5 ratio roller rockers.
Edited by bajean, 02 August 2022 - 12:31 PM.
#39
Posted 07 August 2022 - 03:30 PM
Having torqued the head I then set the clearances for the roller rockers. Next I installed the aldon distributor making sure that the rotor arm was pointing at number 1 cylinder as it was at tdc and ht leads. I then installed the transfer case housing and flywheel assembly. I also painted and heat wrapped the maniflow exhaust manifold.
Posted 07 August 2022 - 03:41 PM
Next I installed the water pump, powerlite micro starter motor and lightweight racing alternator. I also bolted up the twin HS4 carbs and ram pipes. That leaves only the thermostat housing which ill be getting from DSN as well as a couple of other alloy bits next month. I will hopefully be starting the engine outside the car and breaking in the cam. If all goes well i’ll also be swapping it into the car soon after.
Edited by bajean, 07 August 2022 - 03:42 PM.
#41
Posted 09 August 2022 - 06:18 PM
That looks really good
#42
Posted 10 August 2022 - 01:28 PM
You're building my dream engine, very impressive! 8-) 8-)
#43
Posted 11 August 2022 - 09:38 AM
Cheers appreciate the comments, up until a year ago it was still a dream for me too. Hopefully planning on starting it this weekend.
#44
Posted 14 August 2022 - 06:41 AM
Posted 14 August 2022 - 06:45 AM
Video of the engine running.
Edited by bajean, 14 August 2022 - 06:48 AM.
