A very smart looking Mini
1976 Austin Mini
#16
Posted 17 September 2020 - 08:02 PM
#17
Posted 09 October 2020 - 06:42 PM
Posted 10 October 2020 - 04:34 PM
Today I installed the twin hs4, got it to fire up and idle at 900 rpm but still need to set up the fuel mixture, but hey at least it runs ?.
I also installed a braided oil pressure line and relocated the oil cooler behind the grille for a cleaner looking engine bay ( switched from a 13 row to 10 row, which will still do the job just fine ).
The next thing on the list is to sort out the wiring as its a complete rats nest.
Posted 09 November 2020 - 07:38 PM
Finally got the next big piece of the puzzle for the 1293. Med rally spec head with 36/30 valves.
Edited by bajean, 20 March 2021 - 07:03 PM.
#20
Posted 09 November 2020 - 07:57 PM
#21
Posted 15 November 2020 - 10:29 AM
Forged omega pistons 6cc dish ( +0.020 )
forged specialist components rods with arp bolts
balanced, polished & heat treated crank
ACL bearings throughout
Edited by bajean, 16 March 2022 - 12:44 PM.
#22
Posted 19 May 2021 - 07:20 PM
Edited by bajean, 19 May 2021 - 07:26 PM.
#23
Posted 20 May 2021 - 02:01 PM
Nice goodies!
#24
Posted 08 March 2022 - 12:57 PM
Finally got most of the parts for the gearbox build.
- Magnetic oil trap
- uprated sump plug
- baulk rings
- central oil pickup
- Quaife ATB
- SC Drop gears ( with roller bearing )
- SC crown wheel and pinion 3.7
- Billet pot joint covers
- HD Clutch kit
- Miscellaneous gearbox bits
The actual SC CR gear set will be arriving in the next couple of days. Also got a full rebuild kit with bearings and gaskets.
Edited by bajean, 08 March 2022 - 01:06 PM.
#25
Posted 16 March 2022 - 11:19 AM
Last piece of the gearbox build : straight cut close ratio gear set.
Posted 16 March 2022 - 12:39 PM
I am looking forward to seeing how this goes, looks like its going to be a gorgeous enginer to match the Mini!!
YetI
#27
Posted 16 March 2022 - 12:43 PM
#28
Posted 01 April 2022 - 04:45 PM
Finally had some time to build the gearbox ( also my first gearbox build ). Everything went together smoothly and spins beautifully.
Spec :
SC CR Gear set
SC Drop gears ( roller bearing idler gear )
SC Crown wheel and pinion - 3.75
ARP Bolts
Quaife ATB
Billet output shaft covers
Central oil pickup
magnetic plug in oil pickup
All new bearings, laygear shaft , gaskets etc
Edited by bajean, 05 April 2022 - 12:46 PM.
#29
Posted 11 April 2022 - 12:38 PM
Just received my order from KAD with a couple more goodies for the engine build.
- Super finished cam followers
- threaded oil gallery bungs
- bolt kits for clutch housing ( both for clutch cover and housing ) and block to gearbox.
- adjustable lower engine steadies
- KAD race oil pump
- Steel main caps with 4 bolt centre cap.
Posted 06 May 2022 - 08:30 AM
Finally got everything ready to start the engine build. Gave a block a really good clean up with some acidic cleaner and took it to the machine shop to have it, bored to +0.020 over, line bored for the KAD steel main caps, installing new cam bearings, installing new threaded oil bungs and drilled for 11 head studs. Having done all that i will dry build the engine to see exactly how much to remove off the deck of the block to achieve my 11:0:1 CR. Really looking forward to this !!!
