Drive Shaft Snap Ring
Best Answer kiwimike01 , 25 May 2020 - 07:42 PM
I have solved this issue. Turns out I did install the cv on the wrong end so have since pulled it off and put it on the other end and it then went straight into the pot joint and locked in place. Shorter splines into the cv and longer ones into the pot joint. Go to the full post
11 replies to this topic
#1 kiwimike01
kiwimike01
  • 53 posts
Posted 14 May 2020 - 07:05 AM
Hey guys I'm in the process of putting the driveshaft assembly back together and I'm pushing the driveshaft into the pot joint and it goes in fine but I'm not sure if it's far enough because the snap ring doesn't engage and I can pull it back out easily. Is this normal or is there something I should be aware of? Pretty sure I've assembled the shaft properly as only one end wanted to fit into the CV joint.
#2 nicklouse
  • 18,577 posts
Posted 14 May 2020 - 09:21 AM
The inner end will go in until it bottoms out on the shoulder. Which at the same time the C clip should engage. Are you inserting it fully?
#3 kiwimike01
kiwimike01
  • 53 posts
Posted 14 May 2020 - 09:29 AM
yea pushed in fully and even given it a tap with a hammer. ive also put my finger in to see if the pot joint is hard against the collar on the shaft. have tried 3 different snap rings with the same result
#4 kiwimike01
kiwimike01
  • 53 posts
Posted 14 May 2020 - 09:31 AM
Are the splines at each end of the drive shaft the same size and somehow I have put it together back to front? Or is it impossible to do this?
Edited by kiwimike01, 14 May 2020 - 09:36 AM.
#5 GraemeC
GraemeC
  • 7,438 posts
Posted 14 May 2020 - 09:33 AM
Is it a new or old pot joint?
#6 kiwimike01
kiwimike01
  • 53 posts
Posted 14 May 2020 - 09:36 AM
Brand new pot joint. Old drive shaft
Edited by kiwimike01, 14 May 2020 - 09:38 AM.
#7 nicklouse
  • 18,577 posts
Posted 14 May 2020 - 09:38 AM
CV end has a stop ring. Pot joint does not have a stop ring. The shaft has a shoulder. IIRC the splines are the same but I have never tried fitting the wrong way around.
#8 kiwimike01
kiwimike01
  • 53 posts
Posted 14 May 2020 - 09:42 AM
Ok I'm starting to think that I may have installed the CV on the wrong end. I'm trying to find an exploded diagram of how it goes together but can't seem to. I took it all apart and left it for a week without thinking to take photos
#9 nicklouse
  • 18,577 posts
Posted 14 May 2020 - 09:44 AM
Post a picture.
#10 kiwimike01
kiwimike01
  • 53 posts
Posted 14 May 2020 - 09:45 AM
I will have to tomorrow as it's bedtime here and the cars not here.
#11 andyapanel
andyapanel
  • 623 posts
Posted 14 May 2020 - 11:32 AM
Assuming the problem is only the snap ring, make sure the gap is at 6 o clock.
Sometimes a new snap ring will do the trick
Good luck
#12 kiwimike01
kiwimike01
  • 53 posts
Posted 25 May 2020 - 07:42 PM   Best Answer
