Gearbox Rebuild Questions
32 replies to this topic
#16 GraemeC
GraemeC
  • 7,438 posts
Posted 14 May 2020 - 12:18 PM
Yes - he has the Metro double groove gearset and the primary variations in the drop downs
#17 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 14 May 2020 - 02:08 PM
@GraemeC ah didn’t know that, I have changed the Diff though from the stock 2.95 to a 3.44.
3.44 was the preferred ratio for intended driving but how will that be affected with one less tooth on the input gear?
Put the info into the guessworks calculator and see
http://www.guess-wor.../Tech/ratio.htm
I have, but I am never sure of the correct settings e.g. what Drop Gear ratio do I have
I am running 10 Inch 165/70 Tyres.
So:
Tyre Size: 165/70 x 10
Drop Gear Ratio: 1:1 (Standard)?
Gearbox Type: Metro 1.3 HLE (Double groove A+)
3.444:1 18/62 (Most Mini's & post '84 Metro's)
Changing between Metro 1.3 HLE and MkIV Mini and Metro makes no big differences, however the Diff Ratio does:
Selecting a 3.44 which I now have gives this:
And going back to the 2.95 Diff gives this:
I am no expert, but it would seem (if I have the figure correct) that I should have stuck with the 2.95 Diff? The 2.95 appears to offer greater speed at lower revs?
Please tell me I am wrong!!!
#18 imack
imack
  • 2,103 posts
Posted 14 May 2020 - 02:31 PM
2.95:1 final drive will give you lower engine rpm for a given road speed compared with a 3.44 final drive, but the 3.44 will give better acceleration and in gear performance.
With only 4 gears you're always trying to to strike the best compromise for your needs.
#19 GraemeC
GraemeC
  • 7,438 posts
Posted 14 May 2020 - 02:42 PM
Count the teeth on the primary gear and the input gear.  1:1 they will be the same (29 teeth each), other ratios will be as per the drop down on the Guessworks site - either an economy primary (30 teeth), an economy input (28 teeth) or both economy gears.
#20 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 14 May 2020 - 04:21 PM
OK so looks like an Eco Primary (30 Teeth) and Eco Input (28 Teeth), and inserting this adjust the speed / rpm back up a bit e.g. a reduction in RPM per Speed 106 at 6000RPM:
So I should end up with a revvy / torquey / nippy Engine :-)
#21 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 18 May 2020 - 10:21 AM
Quick question - the Diff cover on this Gearbox had these and these Locktabs.
It says in the MiniSpares page that they are listed on that they were only used up until 1982, so I take it that means I don't need to fit them?
This is a Gearbox from a 1989 Metro:
#22 nicklouse
  • 18,577 posts
Posted 18 May 2020 - 10:37 AM
They were used when the studs and nuts were used. Dropped when bolts were used. Add thread lock to the fasteners.
#23 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 18 May 2020 - 12:22 PM
Well that will save some money (if I have the bolts, as opposed to studs that is, I'm sure I do), although I may by new bolts anyway.
What type of ThreadLock? I have some Loctite 243 which I ordered for the threaded Oil Gallery Grub Screws.
#24 NDT
NDT
  • 181 posts
Posted 19 May 2020 - 03:17 PM
I have a rebuild kit so all of the bearings will get swapped out.
Where did you get your rebuild kit?
Minispares ones all claim to be out of stock.
#25 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 19 May 2020 - 06:20 PM
Got mine from Guessworks, but more pricey but promptly answered questions and was really helpful.
http://www.guess-wor...argument=GW_Kit
#26 NDT
NDT
  • 181 posts
Posted 19 May 2020 - 07:25 PM
Thanks - I’ll give him a shout in the morning.
I had hoped to get the box rebuilt over the long weekend.
Seems to be in good condition so I’m not sure about whether to go for the full rebuild kit. Bearings look unmarked for example.
#27 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 20 May 2020 - 12:01 PM
Have you stripped it already? I guess you could build it over a long weekend if you have everything ready?
Check what you get in the rebuild kit as there are a few additional things I am going to have to buy such as:
DAM2377 Locktabs For Double Row Bearing Housing
DAM4000 1st Motion Shaft Nut Locktab
DAM6140 Differential Pinion Locktab
You do get a new nut for the BellCrank (Gear Selector Lever Shaft) but you'll have to reuse the washer or buy one as it is not supplied.
In Johns kit he also supplies a Central Oil Pickup pipe.
There are plenty of rebuild videos on YouTube by Classic Mini DIY, MED Engineering and MiniMania, the MiniMania guy is a little brutal IMHO. You could also watch my ones  ;D although though don't give you a detailed account, more of a 'this is what I did' diary.
You also need a Torque Wrench suitable for doing up the Pinion Nut on the Main Shaft - this is 150lb/ft so a large one is needed.
I have already had my DIff rebuilt, I got John Guess to do it as he was exchanging mine for a different ratio.
Just waiting for a replacement MCB for my garage so I can get the Compressor running and clean up the casing before I can start the rebuild.
Edited by JonnyAlpha, 20 May 2020 - 12:38 PM.
#28 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 20 May 2020 - 12:03 PM
Iv'e done a first clean up of the gear box parts, I am using White Spirit.
What do you guys recommend for cleaning everything up before the rebuild? Like I said I have done the initial clean with White Spirit and then Brake Cleaner or Thinners?
I don't have an Ultrasonic Cleaner or Dishwasher :-(
Also, I guess I can't order Layshaft Thrust Washer or Diff Shims) until I start the re-assembly and identify if I need any?
Edited by JonnyAlpha, 20 May 2020 - 06:29 PM.
#29 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 17 January 2022 - 03:26 PM
Resurrecting this thread to add some questions if I may.
So 2 years down the line and I am still building this engine / gearbox :-)
The engine is now going to be Superchared, CR 8.5 @10 PSI, which according to Stuart Gurr should push out around 13ft/lb torque.
As a result of this change in direction and to account for the extra torque, I have now changed the Diff to a 3.1 and fitting a cross pin (currently being done by John Guess).
To achieve the correct acceleration v cruising speed with the 3.1 Diff, I needed to swap out the Eco Primary and Input Gears. I have sourced a 1:1 Helical Primary and Input Gear, but these are not double grooved and I was wondering if it is ok to use them with a double grooved Idler Gear? If not should I source an A+ Idler Gear (non double grooved)?
P.S. I have contacted Ac Dodd ref re-busing the Primary Gear.
#30 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 17 January 2022 - 03:29 PM
Here's the original Primary Gear:
