Steering Rack Gaiters Torn, Can I Replace Them?
Posted 10 May 2020 - 07:58 PM
Posted 10 May 2020 - 08:02 PM
You can replace just the gaiters, but check for play in the rack, and the track rod ends also, to make sure the rack hasnt worn and the track rod ends are serviceable for re use.
Posted 10 May 2020 - 08:28 PM
It can be difficult to get the new gaiters over the rack end. Youjust need patience.
Don't forget to put sufficient oil in the rack.
Posted 12 May 2020 - 07:35 PM
Posted 12 May 2020 - 10:18 PM
You can get gaiters that are very flexible, and come with a "funnel" to put over the track rod end to stretch the narrow part. However, I just gave in and took the track rod ends off, checking as best I could where the locknut was and re-tracked it afterwards.
At the rack end, fold the end of the gaiter back on itself (like putting on socks), and then it will pop over the rack.
Note your rack may be filled with grease, not oil, so no need to refill unless a lot of dirt has got in. Mine is a '93, and it had grease not oil.
Posted 13 April 2021 - 12:02 PM
Hi, I have a 1992 Cooper, do you know if I need the 4.5" or 7.5" long gaiters?
Posted 13 April 2021 - 07:30 PM
If it has the original Rack, 4.5"
Posted 14 April 2021 - 04:40 AM
Remember to get the alignment checked just incase it changed
Posted 14 April 2021 - 09:28 AM
I struggled for over half an hour one one side, finally gave up and found some good used ones off of an old spare rack.
Posted 14 April 2021 - 09:42 AM
The Gaiters I've been using for a long while - mostly - come from a local supplier and I * think * they are locally made, there's no branding or markings on them and are in a plain clear plastic bag with some cable ties (that I never use). They almost feel quite rubber-like. I've not had issues with them not lasting (10 years +) and are very fairly priced. They are a snug fit on the rack body and a fiddle for sure to fit when the racks on the car (there's not a lot of room there in the right places). I have smeared the big end of the odd one with some lube to help slip them on, but usually with some coloured words, they play the game.
A while back, I did buy some from Mini Spares, they came in a Unipart Box, they appeared almost similar to those that I have been using, just a tad shorter. I found these quite OK actually, but it appears from the experience of others the Unipart ones aren't the same now ?
Posted 14 April 2021 - 09:47 AM
thanks a lot guys. And will I just use the plastic clips that come with the gaiter? ( I presume these aren't cable ties!)
Posted 14 April 2021 - 09:54 AM
If they are the ones I'm think of, they will be cable ties.
Cable ties work OK if you only have grease in the Rack, but if you have Oil, the gaiters won't seal well enough on the rack body to keep the Oil from leaking.
There is a type of Tie that does work though, they call the 'Flatties'. An ordinary Cable Tie, the loose end goes through the head of the tie at 90 degrees, so when pulled up tight, no matter how tight, right under the head, there's no pressure and if you do pull them up quite tight, the gaiter actually puckers up at that point.
The Flattie Ties, have the loose end go through the end of head, so when tighten up, there's pressure all round and so they will get the gaiter to seal.
Posted 14 April 2021 - 01:33 PM
thanks that's great Moke.
