Thrust Washer Size
10 replies to this topic
#1 mickyh
mickyh
  • 391 posts
  • Local Club: not yet
Posted 06 May 2020 - 09:16 PM
Looking for new thrust washers, the current ones in the block measure 0.09 inch; but this seems too big??
Any ideas?
#2 Cooperman
  • 23,276 posts
Posted 06 May 2020 - 11:33 PM
From memory the thrust bearing standard thickness is 0.092".
What you need to do is to buy a set of standard thrust bearings and do a 'trial build', measure the end float and correct with oversize bearings as necessary. The ideal end float is 0.003" to 0.005".
Bearings come in +0.003" size, but if the crankshaft centre journal has had to be machined well down in thickness there is a +.030" set available which can be machined down to get the float exactly right.
#3 Spider
  • 14,838 posts
Posted 07 May 2020 - 12:12 AM
I'm not sure what engine this is for but looking across all the A Series Engines, the standard Thrust Washer (per side) thickness is 0.093".  I couldn't see you needing anything thinner than these unless you were fitting a 1300 type Crank in to a (60's) Cooper S Block.
#4 whistler
whistler
  • 1,791 posts
Posted 07 May 2020 - 09:22 AM
If you look at the back of the thrusts you might find that the stamped part number is a little proud of the surface. Just flatten that off a little.
#5 mickyh
mickyh
  • 391 posts
Posted 07 May 2020 - 10:02 AM
OK, it sound like I just need a standard set I hope; as I have stripped the crank and when I measured the washers that were in there I was getting 0.09-0.091, so i try a standard set and that should cure my end float hopefully.
Edited by mickyh, 07 May 2020 - 10:03 AM.
#6 Cooperman
  • 23,276 posts
Posted 08 May 2020 - 10:26 AM
If you do a trial build with standard thrusts and find that you have more than 0.005" end float, you fit one +0.003 thrust which brings the float to be within tolerance.
If you have more than 0.008" float you fit a pair of +0.003 which again brings you within tolerance.
The maximum acceptable float is 0.006", so anything over 0.012" at trial build means it is necessary to machine down a +0.030" thrust. That is normally necessary where a crank thrust face has been damaged and it has been faced back quite a bit.
#7 Bobbins
Bobbins
  • 1,485 posts
Posted 18 October 2020 - 07:39 PM
Are the oversize thrust washers available for 998 engines?
#8 Spider
  • 14,838 posts
Posted 19 October 2020 - 12:31 AM
I could only see a listing on Mini Spares for standard sizes, but I'm sure if you asked, you'll find they have over sizes as well.
I check one of my suppliers and there is at least Std, 0.003, 0.015 and 0.030" sizes available. I also recall + 0.005" were available too.
#9 Bobbins
Bobbins
  • 1,485 posts
Posted 19 October 2020 - 06:05 AM
For now I've ordered a standard, I'll measure the endfloat once they're in :)
#10 The Principal
The Principal
  • 763 posts
Posted 19 October 2020 - 09:16 AM
MED have standard and 0.003 https://www.med-engi...ust-washer-sets
#11 Bobbins
Bobbins
  • 1,485 posts
Posted 20 October 2020 - 09:12 PM
All assembled with standard thrust washers and there's now 0.004" of end float.
Thanks all.
