1979 Mini Marcos
44 replies to this topic
#1 maph2
maph2
  • 1,291 posts
  • Local Club: Poor Boys Warwick
Posted 05 May 2020 - 09:06 AM
Playing catch up with this thread as it started april2019 on the retro rides forum
Edited by maph2, 05 May 2020 - 09:09 AM.
#2 maph2
maph2
  • 1,291 posts
Last on the road in 1988.
#3 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:07 AM
Overall it's good. The front end needs work. It's had a hybrid marcos-Jem nose job, which isn't to my standard. I do like the Jem noses so have been in contact with the Marcos club about a new mini-jem nose cone.
#4 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:08 AM
Small update....had to pop over to Birmingham so swung by the storage to pick up the Marcos front subframe and boxes of "bits". No idea what's in them so will have a sort out. Subframe needs to be checked for alignment before going to the powdercoaters next week.
#5 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:10 AM
Digging around this morning
#6 maph2
maph2
  • 1,291 posts
Found the original seats. Too narrow for my hips but I've already got seats sorted.
#7 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:11 AM
Garage prep and final sort out. Picked up a car lift at the NEC resto show. Marcos should be here in a few weeks.
#8 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:14 AM
Stripped off the old gaiters and gave the rack a quick paint of rustoleum. Track rods ends are good so will be reused.
First batch of powdercoating
Bodyshell will be RAL 6011 Reseda green.. Mostly green with some black and silver components.
#9 maph2
maph2
  • 1,291 posts
Van hired and the shell collected today. Frikkin heavy on my own.
The eagle has landed
#10 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:15 AM
First stage: clean out the interior and have a look around.
#11 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:16 AM
Dropped the fuel tank out last night. Pulled the fuel level sender out and it looked brand new inside. Tank now at the powdercoaters
This leccy pump was also underneath. Will see if it works. It's possibly never been used as the filter is old but unused.
Float is like new
#12 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:17 AM
Chiselling out a load of bloody expanding foam and some shoddy DIY fibreglassing.
#13 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:19 AM
First bits of glassing to fill in the going rear light holes.
Tonight I've rebuilt the drivers side front subframe mount. At the factory they layered in a 2mm piece of mild sheet steel. They all explode after years of moisture getting in. The options are to replace with mild steel or 304 stainless steel. The third option after speaking with other Marcos owners is to use a layer of carbon weave along with CSM and wovening roving alternating.
Handily I had some carbon fabric so have layered it in tonight. About 9 layers. I'll also use a steel spreader washer plate under the bolts too.
#14 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:24 AM
Rebuilt the passenger side front subframe mount today. About 12 layers with carbon fabric in there too.
Edited by maph2, 05 May 2020 - 09:25 AM.
#15 maph2
maph2
  • 1,291 posts
Posted 05 May 2020 - 09:25 AM
Drivers side rear subframe heelboard mount. steel has exploded and popped the gelcoat. First job last night was to glass in layers of CSM, woven and a layer of carbon on the inside. Tonight i'll dig out the rust, clean and glass in. Not replacing the steel as I'm using a 5mm steel base plate on the inside as part of the rollcage mounting.
