Wheel Bearing Failure
69 replies to this topic
#61 nicklouse
  • 18,601 posts
Posted 29 September 2020 - 11:12 PM
Just to make the colours more confusing, I have had Blue Rubber Grease.
As Graeme mentioned, don't go off the colour for it's use.
Dam you are lucky I have to do with clear rubber grease.
#62 IronmanG
IronmanG
  • 1,236 posts
  • Local Club: Box hill. Lsmoc member
Posted 30 September 2020 - 05:56 AM
Ok cheers
#63 IronmanG
IronmanG
  • 1,236 posts
Posted 30 September 2020 - 06:54 AM
Attached File  Screenshot_20200930-075122_Gallery.jpg   20.9K   3 downloads
#64 I hate Brian
I hate Brian
  • 782 posts
Posted 30 September 2020 - 08:02 AM
What about this grease
Lucas Oil 10574 Red and Tacky Grease, 454 g
#65 Rusty Nut
Rusty Nut
  • 21 posts
Posted 01 October 2020 - 07:06 PM
From what I see the Timken red grease is NLGI 2 and Lithium based so I presume any grease with this spec would be fine for use.
Both Timken and SKF (LGHP 2) rate  to 149 degrees c . I hope mini wheel bearings don’t get hotter than that!
it is confusing though!
General purpose i thought was for gate hinges!
#66 SKIDDERWOLF
SKIDDERWOLF
  • 301 posts
Posted 13 November 2022 - 02:24 PM
Bought this bearing from Minispares GHK1018 which failed on me today , inner race seems to have fallen apart, Had been cruising at around 50mph when the car made a horrendous noise from offside front, pulled over to see hot grease and smoke coming from inner race. Managed to limp it home and tore it down to find disintergrated bearings , cage is damaged and outer race has signs of overheating.
#67 Mr Piggy
Mr Piggy
  • 52 posts
Posted 14 November 2022 - 09:32 AM
We used to use LM in the dealers in the 70's and didn't have any problems. I use BNS now as it's a higher spec and is what we used in primary gears. Had to buy a big tub of it from a farm suppliers about 20 yrs ago but may be able to find on the net now.
#68 andyapanel
andyapanel
  • 624 posts
Posted 14 November 2022 - 12:47 PM
I have never had a problem with Minispares bearings, though I did with a set of Timkens which failed after a few hundred miles.
Did you preload the bearing before you torqued everything up?
Is the hub still OK?
Good luck getting to the bottom of it.
#69 SKIDDERWOLF
SKIDDERWOLF
  • 301 posts
Posted 14 November 2022 - 06:11 PM
Hub looks to be ok, these were std bearings not taper roller and I must admit that I didnt do any preload just installed the bearings into the hub refitted the CV joint and tightened to spec. Is there another step I should have done?
#70 Lplus
Lplus
  • 905 posts
Posted 14 November 2022 - 08:58 PM
The hub bearings should be preloaded by the internal spacer between the two inner races and the step in the hub between the outer races both being the correct thickness.  If the outer step wears the bearings still have play when new, if the inner spacer wears the preload would be excessive.
