Tachometer On A+
4 replies to this topic
#1 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 30 April 2020 - 12:31 PM
I am trying to get a tachometer to work on my Elf. I bought a cheap 52mm tachometer to go into one of the holes in the dash, the other hole now has a dual gauge.
According to the instructions, the wires are Red - Ignition 12v, Black - battery neg, green to coil neg. there is also another red & black for the backlighting. The engine is a 1275 A+ with electronic ignition.
I picked up a live & earth behind the dash and connected the green to the Neg on the coil.
When I switched on the ignition I saw the needle go straight to 8000rpm. I assumed the green may be wrong so disconnected it. The needle was still on 8k. So with only the red (pos) & black (neg) connected the tachometer goes straight to 8 when switched on!
is this correct or is the gauge goosed?
#2 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 30 April 2020 - 02:14 PM
it sounds correct, does the gauge have a switch on the back at all to adjust for amount of cylinders etc?
also did you try to run the car as maybe the gauge calibrates on first use.
#3 DUF2
DUF2
  • 456 posts
Posted 30 April 2020 - 02:20 PM
Yes, switch on the back, 8, 6 & 4 cylinders, set to 4 cylinders.
No not run it with Tachometer connected, will try it next time I’m working on the car. Thanks
#4 craig 1010cc
craig 1010cc
  • 1,165 posts
Sounds like a duff gauge if just power to the gauge is maxing it out.
#5 DUF2
DUF2
  • 456 posts
Posted 30 April 2020 - 06:24 PM
I will have another go tomorrow, I do have an inkling it may be goosed!
