Rubber Bungs For Heater Pipe Holes In Bulkhead
9 replies to this topic
#1 BAWrathall
BAWrathall
  • 29 posts
Posted 28 April 2020 - 07:25 AM
Hi I’m looking for some bungs to blank of the highlighted holes, I can’t find a part number , if anyone knows that would be great
thank you
Bradley
#2 mab01uk
mab01uk
  • 12,413 posts
Posted 28 April 2020 - 07:28 AM
Not sure if anyone does blank grommets for the elongated holes for 5/8" heater hoses as Minis from that era always had a heater fitted....
HEATER HOSE GROMMET LARGE,FOR HOSE THROUGH BODY:-
http://www.minispare...ic/CLP6235.aspx
GROMMET-HEATER HOSE THROUGH DASH-5/8'' DIAMETER HOSE £2.88 Inc VAT
Part Number: CLP6235
http://www.somerford...roducts_id=1487
Cooling- Heater Hoses, Water Control Valves and Cables 1988 On:-
http://www.somerford...age=page&id=102
Edited by mab01uk, 28 April 2020 - 07:37 AM.
#3 DeadSquare
DeadSquare
  • 3,089 posts
Posted 28 April 2020 - 07:49 AM
Gaffer tape both sides.
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 28 April 2020 - 09:18 AM
You can try insert a blind grommet into the current elongated type grommets
#5 BAWrathall
BAWrathall
  • 29 posts
Posted 28 April 2020 - 09:20 AM
Thanks Mab01uk that’s all I could see I was hoping I had missed one somewhere
#6 BAWrathall
BAWrathall
  • 29 posts
Posted 28 April 2020 - 09:21 AM
Cal844 I think that’s what I will have to try I’ve done that with the rest , I’ll have to buy some larger ones and just try them
#7 BAWrathall
BAWrathall
  • 29 posts
Haha always a possibility but want it to look a bit cleaner
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 28 April 2020 - 10:31 AM
How about making some blanking plates, either bond them on or bolt them on and colour code them. Whatever you use you need to make sure they seal.
#9 BAWrathall
BAWrathall
  • 29 posts
Posted 28 April 2020 - 11:26 AM
I think I might have to , I’ll try source some rubber bungs to try if not I’ll plate I wish I’d I welded up before painting but to late now
#10 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 28 April 2020 - 01:25 PM
I dont mean as in welding them in place, either make an insert to the size of the hole you have got, bond that onto a slightly wider backing plate, paint to match the bulkhead then bond the whole thing in place.
If in the future you need to reuse the hole you can pop the blanking plate off.
