Fitting A Facet Fuel Pump
6 replies to this topic
#1 JeremyduP
JeremyduP
  • 46 posts
Posted 27 April 2020 - 01:09 PM
Those of us who have suffered failures of the ‘new’ SU fuel pumps (four in 4 years) will reluctantly have looked for alternatives. The ideal would be an original SU pump which never seemed to fail. Failing that, there’s the non-Mini Facet pump which I have gone for.
There are of course a few problems. You can’t just bolt it into the original SU pump mounting holes in the subframe because the Facet mounting points are at right angles to the direction of the fuel flow, which would mean the fuel pipe sticking out into the centre of the subframe. Not a good idea.
But I realised the original holes could be used in a different way. I mounted one of the Facet feet into the rear original hole in the subframe and rotated it so the fuel outlet faced forward. I then cut a 100mm length of flat steel and bolted it to the front original hole and offered it up to the other Facet mounting donut.  See below.
Attached File  IMG_6288.JPG   64.52K   9 downloads
I marked the steel bar and drilled a hole for the second Facet mounting point. The picture shows the finished setup.
Attached File  IMG_6295.JPG   66.59K   12 downloads
I have shown it with the bar below the subframe so it’s easier to see how it fits. To finish I moved the steel bar above the subframe (sorry I forgot to take a picture). It needed a large loop of rubber hose at the front because the metal fuel pipe was so close.
I'm sure others have tried other mounting methods (boot, under seat, under the dash), but I wanted the pump under the car and in the same place and with as little work as possible.  I hope this helps others.
The pump works well, but it is a little disconcerting that it continues to tick when the floats are full.  Of course you can't hear the tick when the car is running.
#2 nicklouse
  • 19,057 posts
Posted 27 April 2020 - 01:20 PM
I think I would be drilling two new holes and buying some 90 degree ends.
#3 KTS
KTS
  • 2,490 posts
Posted 27 April 2020 - 01:49 PM
I found just one extra hole was required to mount as facet recommend
#4 Cooperman
  • 23,564 posts
Posted 27 April 2020 - 04:57 PM
Just turn the pump upside down and bolt it through the horizontal rear seat base panel Works for me and I fit twin pumps for maximum reliability.
The Lucas pumps were always a problem and we used to carry a piece of wood to thump the pump with.
#5 Spider
  • 15,842 posts
Posted 28 April 2020 - 04:22 AM
I know you're already committed to your Facet, but the Hardi Pumps that Mini Spares offer, basically a German SU Copy, I've found to be very good. They'd bolt up where the SU was.
#6 JeremyduP
JeremyduP
  • 46 posts
Posted 29 April 2020 - 10:43 AM
Thanks. That’s interesting to know.
#7 Ado1379
Ado1379
  • 588 posts
Posted 30 April 2020 - 07:14 PM
Thump the pump!! ?
