Hif44 Rebuild Kit
Best Answer alex-95 , 16 April 2020 - 09:41 PM
I think I bought the kit you're looking at and ended up buying a solid butterfly with out that bit. I was recommended CRK 162 on the SU website which has the solid butterfly you want.
From another thread:
It's part of the emission control, to reduce NOx. It bleeds some air in to the manifold on very high manifold vacuums, eg, coasting down a hill. There's a number (usually) stamped next to it, like 27.5. That's the in/mg vacuum at which it starts to open.
I solder them shut or fit a blank type butterfly.
Go to the full post
3 replies to this topic
#1 JDImini
JDImini
  • 679 posts
Posted 16 April 2020 - 08:54 PM
Hi
I've bought a HIF44 carb and looking to rebuild it. The suggested kit has the highlighted brass attachment to the butterfly
Attached File  Untitled.jpg   25.99K   0 downloads
but the existing carb doesn't have it.
Please can some explain what the attachment is
Darren
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 16 April 2020 - 09:41 PM   Best Answer
#3 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 16 April 2020 - 11:19 PM
As suggested above bin it. Solder the hole or get a solid butterfly. They are a huge restriction to airflow to.
Phil.
#4 JDImini
JDImini
  • 679 posts
Posted 17 April 2020 - 05:54 PM
Phil.
 Thank you both! very helpful  :D
