What Puller Are People Using For Removing The First Motion Shaft Bearing?
14 replies to this topic
#1 nicklouse
  • 18,577 posts
Posted 16 April 2020 - 12:16 AM
As above
What puller are people using for removing the first motion shaft bearing?
links would be good.
would the wiper/battery terminal puller do it?
#2 Spider
  • 14,841 posts
Posted 16 April 2020 - 12:46 AM
Is this the Outrigger Bearing that's half on the Shaft and the other half in the Transfer Housing ?
I have a Thin Jaw Bearing Puller (I think it's a Sykes ?), that has fixable jaws that gets in nicely.
I've had that for over 30 years now.
I've seen some guys make a puller from some 50 x 50 x 2.5 / 3.0 mm Box Section Tube, about 40 - 50 mm long.
Cut a slot in one side, so it can slide behind the Bearing, weld a nut (probably about 7/16 - 1/2") opposite, then wind a bolt in and it should remove the bearing.
I think Matt Read (?) was offering these too.
#3 nicklouse
  • 18,577 posts
Posted 16 April 2020 - 01:11 AM
What is the approximate size of that one?
mm might have some box section about as well.
#4 Spider
  • 14,841 posts
Posted 16 April 2020 - 02:35 AM
It will just do diff bearings, so a 3" / 75 mm Spread and roughly a 4" / 100 mm reach.
#5 OzOAP
OzOAP
  • 384 posts
Posted 16 April 2020 - 05:17 AM
I use battery terminal puller. Minispares sell one but I got one from local motorfactors
#6 Rorf
Rorf
  • 866 posts
Posted 16 April 2020 - 07:59 AM
A far easier method is to remove the roller bearings and plastic cage, and then undo the nut with a socket. As the nut loosens it will push that bearing inner race off.
#7 DeadSquare
DeadSquare
  • 3,089 posts
Posted 16 April 2020 - 08:31 AM
I have always balanced the box on its speedo end with the top leaning against a wall, and used two tyre leavers, slipping increasingly thicker fulcrum objects under the leavers until the bearing is off.
#8 whistler
whistler
  • 1,791 posts
Posted 16 April 2020 - 08:59 AM
Edited by whistler, 16 April 2020 - 09:00 AM.
#9 nicklouse
  • 18,577 posts
Posted 17 April 2020 - 09:07 PM
Made up some box with a nut welded on.  And a open 20mm hole in it. Works fine.
ps have used two levers before etc but wanted something a bit “better”.
Edited by nicklouse, 17 April 2020 - 09:08 PM.
#10 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 17 April 2020 - 09:57 PM
Thought I may as well add how I removed mine, Bit of brass turned down and then milled a slot to slip behind the bearing and then used a puller on that.
#11 nicklouse
  • 18,577 posts
Posted 17 April 2020 - 10:17 PM
i do like that.
better get an image of my "tool"  as for those of us that don't need every tool under the sun but have a drill and a welder you just need to have a think on.
ps i do want every tool but some times...
oh i will be getting a set of pullers like Mokespider showed above as sometimes they are just good to have. will be popping the diff bearing out of their races later....
#12 nicklouse
  • 18,577 posts
Posted 19 April 2020 - 05:08 PM
it was just some old box section that was zinc coated
M10 bolt tapered to center on the shaft both holes drilled at the same time with a stepped drill bit.
#13 alex-95
alex-95
  • 6,025 posts
Posted 19 April 2020 - 06:00 PM
Thats nice and simple. :thumbsup:
Edited by alex-95, 19 April 2020 - 06:00 PM.
#14 nicklouse
  • 18,577 posts
Posted 19 April 2020 - 06:31 PM
Just thinking if you don’t have a welder you could still use this idea but put the nut on the other side (inside) and hold it with a spanned. It would still work.
#15 Spider
  • 14,841 posts
Posted 19 April 2020 - 06:47 PM
Nice work Nick ;D
