What Size Compressor.
13 replies to this topic
#1 muzzy
muzzy
  • 33 posts
Posted 13 April 2020 - 05:15 PM
Hi i wonder if someone could tell me what size compressor to buy for my diy garage.ive got a DA sander,air grinder,air ratchets and spray gun etci would like it to be well on top of its job and not struggle to supply air.all advice will be gratefully received.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 13 April 2020 - 05:20 PM
The $64000 dollar question.
So from my point of view and owning a lot of air tools (aviation industry) i run a 4hp belt driven 200ltr compressor in my workshop and this runs everything at full speed other than my high speed die grinder, although its not far off. I also use this to spray with.
Now i also have a 3.5 hp 100ltr V twin compressor at home. This will also run all of my air tools but not at full speed especially my DA and high speed grinder.
#3 muzzy
muzzy
  • 33 posts
Posted 13 April 2020 - 05:35 PM
To be fair I was looking at 4hp 100litre 14cfm but wasn't sure if that would run everything so thought it better to ask for advice.The one ive got that's just broke would run my DA but it was continually running which I didn't like.
#4 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 13 April 2020 - 06:06 PM
That was the problem with my compressor at home. It will run pretty much continually when using a DA or my high speed die grinder. The 4hp 200ltr is an old compressor my son gave me and it does the job. Not the quietest machine but perfect for my needs.
If i was a professional then i would be paying big bucks for a rotary screw type compressor.
#5 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 13 April 2020 - 06:44 PM
Mine's 20 cfm and I wouldn't want any less for your application
#6 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 13 April 2020 - 07:21 PM
I just bought a sig 14cfm 150 litre. Runs my bead blaster no problem at all.
.brilliant bit of kit and think it was 240 quid ish
#7 muzzy
muzzy
  • 33 posts
Posted 13 April 2020 - 07:24 PM
thats good value for money the sig i was thinking a minimum of 14 cfm
#8 IronmanG
IronmanG
  • 1,228 posts
Posted 13 April 2020 - 08:06 PM
Its he biggest 1 they do 230volt plug in
#9 IronmanG
IronmanG
  • 1,228 posts
Posted 13 April 2020 - 08:10 PM
https://www.sgs-engi...air-compressor#
#10 IronmanG
IronmanG
  • 1,228 posts
Posted 13 April 2020 - 08:11 PM
Sgs and 100 sorry
#11 Avtovaz
Avtovaz
  • 1,232 posts
Posted 13 April 2020 - 08:24 PM
your best buying some cheep lekky tools and a 50 ltr v twin compressor. I have a lekky DA that works really well, its quiet too.
#12 Harry L
Harry L
  • 63 posts
Posted 13 April 2020 - 11:00 PM
You have a lot of very air hungry tools so I would be looking at something at 150L and 14CFM as a minimum. I've just bought one for my new space as I currently use a 50L compressor, this runs out of air very quickly when using things like a die grinder and spray gun.
I would probably suggest you look to get the most powerful & largest unit you can justify and fit in the space you have!
Don't forget that the average 3HP ones are on the limit of being safely fed from a 13a supply, anything more powerful and you'd have to start looking into having a beefier power supply installed.
#13 Daz1968
Daz1968
  • 2,058 posts
Posted 14 April 2020 - 12:01 AM
I have a 3hp 100 litre Clarke compressor, runs most things ok, blasting can be slow as I have a cabinet but my da sander worked fine, it also ran an airfed mask with a devilbis sri but wouldn’t cope with a full sized gun and airfed, I gave up on my air da due to noise and couldn’t really warrant compressor 3hp running pretty much flat out for sanding, I ended up buying a Mirka ceros sander, it is superb and as good as an air da, far quieter and uses much less electricity than the compressor. The Clarke doesn’t run off a 13amp plug and needs 16amp minimum, although it’s wired direct on a 20amp breaker. If I was doing more spraying I would get another 3hp and run in tandem as spraying and using an airfed mask is very heavy on air.
#14 muzzy
muzzy
  • 33 posts
Posted 14 April 2020 - 08:22 PM
thank you for all your replies its certainly given me a few things to think about.
