Pdwa Valve Siezed?
Posted 08 April 2020 - 02:52 PM
Topped up the master cylinder and tried to bleed the rear brakes first. And I can't seem to get any fluid through. At the end I managed to get a dribble out but this has made no difference really to the master cylinder level.
Would this suggest the Pdwa valve is shot?
Posted 08 April 2020 - 03:04 PM
The bottom from master cylinder does the front to rear and the top of doing the fronts. Is this right or wrong?
Edited by hazpalmer14, 08 April 2020 - 03:15 PM.
Posted 08 April 2020 - 04:36 PM
I'll hazard a guess that you mean FAM7821. This one's upside down, but the ports for the front circuit are opposite one another whereas the outlet for the rear is is nearest the nut end (rear inlet is nearest the mounting hole.)
Bleed the rear circuit first to stop the front closing it off. Sealing the front circuit before the FAM valve would help or use a syringe & bit of hose to pull the fluid through with vacuum.
PDWA is "pressure differential warning actuator" an is summet else with a leccy switch.
When I had this problem (also yellow tag master cylinder) it turned out to be collapsed rear flexible hoses. Have since replaced everything with braided.
Posted 08 April 2020 - 05:35 PM
Yes a FAM7821. It was the NS rear I was trying to bleed first. I've heard pumping it a few downs and holding it down before undoing the bleed nipple might help and might take a few attempts to get fluid through.I'll hazard a guess that you mean FAM7821. This one's upside down, but the ports for the front circuit are opposite one another whereas the outlet for the rear is is nearest the nut end (rear inlet is nearest the mounting hole.)
How would I seal the front circuit?
Edited by hazpalmer14, 08 April 2020 - 05:40 PM.
Posted 08 April 2020 - 11:03 PM
make up something to blank a pipe connection. I've a collection of old pipe unions with short bits of pipe crimped over a few times at the cut off end.
Posted 09 April 2020 - 02:49 AM
I had this problem on one of my cars and used this method to get them bled.....worth a try. I didn't think this up, it was in the back pages of an old Haynes manual.
So, with the MC topped with fluid, open the rear brake bleeder (I use a hose into a bottle with an inch of fluid in the bottom so it can't draw air back in) push down smoothly on the pedal, hold three sec then let up slowly. Wait 15 sec, then repeat. Once you get good clean fluid and no bubbles, close the bleeder and move to the other rear brake - repeat till again clean, clear fluid with no air in it. Bleed the fronts the normal way.
This was the only way I could get fluid to flow out the rear bleeders on my 1980 Estate, but it worked.
Posted 09 April 2020 - 05:41 AM
I had no end of head scratching with my FAM7821, eventually replaced it with a brake proportion valve - all the head scratching was gone.
This one: https://www.mcgillmo...-knob-type-677/
Posted 09 April 2020 - 06:08 AM
The only way the pdwa doesn't lock is to open the bleeders before applying présure. Actually easyer with an EasyBleed and an assistant...
Edited by MacGyver, 09 April 2020 - 06:10 AM.
Posted 09 April 2020 - 05:01 PM
Posted 09 April 2020 - 10:10 PM
Managed to get bleed the fronts today and get fluid out the rear on one side. I have lost the right size spanner I need for the nipple so once I got a good flow of fluid I packed up for the day. I'll revisit it when I find the spanner and do a more thorough job. Thanks for your help
Not left it on the other bleed nipple like my Dad did once? ... found it a couple of months later ... still there but very rusty!
Posted 10 April 2020 - 11:34 AM
Not left it on the other bleed nipple like my Dad did once? ... found it a couple of months later ... still there but very rusty!Managed to get bleed the fronts today and get fluid out the rear on one side. I have lost the right size spanner I need for the nipple so once I got a good flow of fluid I packed up for the day. I'll revisit it when I find the spanner and do a more thorough job. Thanks for your help
No sadly not. I think it's a 7mm. If its imperial I have 1/4 and it isn't that. Need to clean out the mini and sort out my tools. I finish working on it and don't return my tools so they are scattered in the mini some where.
