One Tight Big End Bearing
Best Answer Rorf , 07 April 2020 - 11:32 AM
That is why it is so critical to do a trial build without  the piston rings in place, so if one piston and rod tightens proceedings up you can swop them around to see if the problem moves with that particular rod or it might be the journal.
It could even be a bent rod.
The other reason for doing a trial build is to check whether the block might need decking to get the pistons flush with the deck.
Remove the rings and do a trial build.
Some builders call it a dry build, to ensure no tight spots when turning the crank.
Go to the full post
20 replies to this topic
#16 timmy850
timmy850
  • 3,329 posts
  • Local Club: MITG
Posted 07 April 2020 - 10:31 PM
What do you mean by piston and rod? The pin in little end?
The rods are offset, if it’s around the wrong way it’ll bind up
Attached File  EF5CBC9C-B84F-4609-AC30-AE489EC1E413.jpeg   27.68K   0 downloads
#17 Moshtaraq
Moshtaraq
  • 86 posts
Posted 07 April 2020 - 10:54 PM
No it's on the right way ?
#18 Spider
  • 14,843 posts
Posted 08 April 2020 - 06:03 AM
It's likely cold comfort or news you don't want, but Rods do need to be reconditioned as just one part of the engine reconditioning process. Personally, I wouldn't remotely consider trying to assemble an engine in which there weren't done.
This was covered recently in this thread;-
http://www.theminifo...izing-big-ends/
#19 Moshtaraq
Moshtaraq
  • 86 posts
Posted 08 April 2020 - 06:49 AM
And how much will that cost me?
#20 Spider
  • 14,843 posts
Posted 08 April 2020 - 09:33 AM
I'd suggest you ask your favorite machine shop, but, when I last looked, it worked out about the price of a complete set of gaskets.
#21 Moshtaraq
Moshtaraq
  • 86 posts
Posted 08 April 2021 - 12:23 PM
Turned out the rod was bent slightly, bought a new one and spins feely now.
