Oil Control Rings Problem?
2 replies to this topic
#1 blacktulip
blacktulip
  • 6,224 posts
Posted 05 April 2020 - 10:14 PM
Upon hand turning my 998cc cooper engine the piston seems to bring oil up the bore and leave it there upon going down again. Is this normal?
This is on the way up where I have wiped it away...
And this is going down after tdc...
Edited by blacktulip, 05 April 2020 - 10:15 PM.
#2 nicklouse
  • 18,687 posts
Posted 05 April 2020 - 10:30 PM
If there is oil above the rings it will be visible. That’s how rings work.
the oil control rings job is to not let oil pass. Normally keep it in the engine. But if there is some above it does the same.
when you took the head off some will have got into/onto the bores.
#3 blacktulip
blacktulip
  • 6,224 posts
Posted 05 April 2020 - 10:43 PM
There was a bit in there yes so I will take a chance on it. Great advice Nick cheers
