Hello everybody,
I decided to start a topic about general questions I have and will have during the build of my project.
First question I have now is concerning the flitch panel and in particular its shape where the A-panel is clamped on at the A-pillar:
How does the corner fit on the door step? I have no idea as everything was rotten. I've done the other side, there is about a 3mm gap all around, but I'n either not sure if it's right like this, everything was rotten too.
This side looks like this at the moment (I have some metal to cut, but I prefer to ask before doing it)
This is a view from the wheel well, the hole on the top is the lowest door hinge hole.
Here I have no gap between the corner and the doorstep. There is too nuch metal et the moment, I will have to cut some out, but do not know how much, andmake place for folding the A-panel around that corner.
From the top, inside, where the hinges are mounted:
Does this shape seem OK for you?
Thanks,
Gilles
