Gearbox Thread
9 replies to this topic
#1 Spider
  • 14,843 posts
Posted 25 March 2020 - 07:15 AM
Guys, there was a recent thread on Gearboxes, asking about pros and cons between 2 different types.
I'm awfully sorry and embarrassed that in an attempt to clean up a double post of mine, I deleted the thread.
Sorry for that.
I'm seeing if we can get it back.
#2 unburntfuelinthemorning
  • 1,982 posts
Posted 25 March 2020 - 08:12 AM
Ooops!  These things happen.
#3 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 25 March 2020 - 08:32 AM
You gert buffoon Chris!  ;D
#4 unburntfuelinthemorning
  • 1,982 posts
Posted 25 March 2020 - 09:33 AM
Well I was trying to be nice!
#5 Spider
  • 14,843 posts
Posted 25 March 2020 - 09:45 AM
And then some !
#6 Spider
  • 14,843 posts
Posted 25 March 2020 - 09:46 AM
Cheers mate, but I take as good as I give and well,,,, I deserve to take lots over this !
#7 dotmatrix
dotmatrix
  • 439 posts
Posted 25 March 2020 - 11:57 AM
speaking of gearboxes did you see MED's video on putting bigger bolts and studs in between the block and gearbox? I didn't know this was a thing/problem that needed solving.
#8 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 25 March 2020 - 12:38 PM
Good for high revving engines, not common on boosted engines.
#9 Spider
  • 14,843 posts
Posted 25 March 2020 - 06:08 PM
This type of conversion was mentioned in Vizard's early book 'How to Modify your Mini'.
I've never found the standard arrangement an issue and speaking over the years with a few local guys, including racers, they too just use the standard 1/4" screws and studs.
#10 imack
imack
  • 2,104 posts
Posted 25 March 2020 - 06:20 PM
I've been running 5/16" bolts in the block / gearbox flange for 30 years, having said that I never really had problems with the 1/4" bolts in my previous engines although they were lower power output.
5/16" bolts with a 1/2" a/f head are pretty awkward to tighten and remove.
On my last rebuild I used the 5/16" MED bolt and gasket set. Easier to install the cap head bolts but still more fiddly than 1/4 bolts.
