Hi,
I'm having a problem with the door alignment on my restored shell.
When I got the shell back the door gaps were perfect. I then fitted the door seals and check strap seal and it seemed to throw it out of alignment. To the point that the door is now catching on the B post. I've removed the seals but it has now stayed in that position.
When I try to tighten up the hinge nuts in the wheel arch, the top one is just spinning on the thread. Is this a likely cause to my problem?
