Drive Shaft Lengths
16 replies to this topic
#1 Carlos W
Carlos W
  • 10,114 posts
Posted 06 March 2020 - 06:28 PM
I've got a box of different A series drive shafts. (no cvs on them)
Has anyone got a list of lengths of driveshafts from different years please?
#2 nicklouse
  • 18,576 posts
Posted 06 March 2020 - 10:15 PM
what inner CV fitting?
#3 Spider
  • 14,838 posts
Posted 07 March 2020 - 04:47 AM
Sorry, but I don't have the actual lengths here, but some useless information.
There's several families of drive shafts that look similar but for different cars, ie. the Mini (of course!), the ADO16, Metro etc
There's also different inboard ends, depending on whether they can was fitted with Inboard CVs,or Uni-joints, and on the latter, there is 2 lengths here, depending on Rubber type Uni Joints or the steel Hardie Spicer types.
Among Minis, there was on 3 types and 2 lengths in each, depending on being for the RH or LH Sides.
#4 Rorf
Rorf
  • 866 posts
Posted 07 March 2020 - 05:23 AM
Well how about giving us the lengths, and diameters of the half shafts you have there, and possibly the forum members have a better chance of supplying the information you require.
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 07 March 2020 - 07:31 AM
The first set are 32 and 39.5 cm
Then I've got some that are 37 and 45cm
#6 nicklouse
  • 18,576 posts
Posted 07 March 2020 - 09:19 AM
And what fitting on the gearbox end?
#7 GraemeC
GraemeC
  • 7,438 posts
Posted 07 March 2020 - 10:20 AM
Splines  :P
#8 nicklouse
  • 18,576 posts
Posted 07 March 2020 - 11:49 AM
Which? Early or late.
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 07 March 2020 - 01:07 PM
What's the difference between early and late splines?
#10 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 07 March 2020 - 10:03 PM
The pot joints have different splines to the early rubber/Hardy Spicer
I don’t know what the difference is, but they don’t swap over
#11 Tonylamb
Tonylamb
  • 358 posts
Posted 21 March 2020 - 08:14 AM
I'm interested in this as I used the drive shafts that came with the 1000HL A+ series engine. They have pot joints. The passenger side shaft keeps sliding off the diff. I think that is due to the circlip being missing and will be looking at that this weekend. However I wonder if I should change the drive shafts are 1275 shafts longer or stronger than the standard ones?
#12 Spider
  • 14,838 posts
Posted 21 March 2020 - 10:09 AM
The problem here will be the clip - or the lack of one. That's all that keeps them in and nothing else.
1275 and 998 shafts are the same.
#13 Tonylamb
Tonylamb
  • 358 posts
Posted 21 March 2020 - 09:37 PM
perfect thanks I will have to take the shaft out and get a circlip in there.
#14 nicklouse
  • 18,576 posts
Posted 21 March 2020 - 09:39 PM
totally different.
early
#15 Tonylamb
Tonylamb
  • 358 posts
Posted 04 April 2020 - 09:22 PM
So I've just got round to taking the driveshaft out. I got some new circlips for the job. However I can't see how the clips fit. I know the driveshaft has a circlip each end one under the pot joint and one on the outer CV. But the issue I have is that the pot joint is sliding off of the shaft from the differential. I can't see on any diagram where there is a clip that holds the pot joint onto the differential shaft. Before I vainly take it all apart can someone confirm that there is indeed a circlip that holds the pot joint tight to the differential oil seal and housing? I'm wondering if the drive shaft is the right length. it was with the car which was a 998 I believe and I now have a 1275 A+ engine. I believe they are the same size and length. or maybe i have this wrong do the clips hold the pot and CV joints out far enough to hold the pot joint in the right place?
