Any idea how my engine bores
Liners look.
Do you think a honing is fine or a bore?
Posted 05 March 2020 - 07:27 PM
Posted 05 March 2020 - 08:21 PM
If there is any form of a step at the top of the bore it`s time for a rebore and new pistons.
Late A+ 998 motors are bullet proof so i`m wondering why it is in bits, was there an issue as they will generally go on forever and smoking issues are usually down to the valve guides and not the rings.
Even with a large step at the top of the bores they will not give any trouble as long as they are not pulled apart.
Posted 05 March 2020 - 09:52 PM
Posted 05 March 2020 - 09:57 PM
OK, rebore + 0.020" new pistons, check crank for oval.
It`s in bits now so a full rebuild it is.
Posted 05 March 2020 - 10:03 PM
Posted 05 March 2020 - 10:20 PM
Posted 05 March 2020 - 10:29 PM
Posted 05 March 2020 - 10:31 PM
Posted 06 March 2020 - 11:35 AM
minispares has them too. I just did my 998 and rebored to +.20 with an AC dodd RS cam and so on.
Posted 06 March 2020 - 12:03 PM
Mini Spares P22463-20 is the piston which should work well for you. The gudgeon pin is press-fit-type (check that you have the rods for this)..
After re-boring, do a trial build and measure how much needs to be skimmed from the block deck in order to bring the piston tops up to within 0.005" of block deck level at TDC.
Posted 06 March 2020 - 12:10 PM
Posted 06 March 2020 - 12:16 PM
Posted 06 March 2020 - 12:23 PM
Posted 06 March 2020 - 08:14 PM
Posted 06 March 2020 - 10:20 PM
