Brake Fluid Question, Dot 5 Vs Others
13 replies to this topic
#1 dasupersprint
dasupersprint
  • 848 posts
Posted 28 February 2020 - 03:17 PM
Hello,
To put you into context, my Mini is under a long restoration. Two years ago, I rebuilt the braking system, all in new, except for the master. I put DOT 3 or 4 fluid into the system.
Fast forward to last week, I decided to change the master too. I've been recommended to put DOT 5 fluid in my system.
My question is: Do I need to drain everything in the pipes before I put DOT 5 in them? Or could I put DOT 5 in the master first and push the pedal until the purple fluid comes out?
Thanks again!
#2 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 28 February 2020 - 04:21 PM
I wouldn't put DOT5 in my system, even if new.
- not compatible with other DOTs (think about having an issue on the road, you Must find DOT5...)
- does not absorb water, but I feel better opening one in a while mw system to check everything.
- maw cause problems withs gaskets and so on. If so wou can change all the system.
I will take DOT4 or 5.1 the day my car is so far.
#3 dasupersprint
dasupersprint
  • 848 posts
Posted 28 February 2020 - 04:33 PM
Is there any advantage to DOT 5 other than not dangerous for paint?
#4 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 28 February 2020 - 04:39 PM
Can you confirm you want to put Dot 5 or Dot 5.1 in, as there's a significant difference.
If it is Dot 5, then yes, the system will have be utterly dry.
Edited by Steve220, 28 February 2020 - 04:41 PM.
#5 Rorf
Rorf
  • 866 posts
Why complicate things - stick to DOT 4 and change it every 2 to 3 years.
#6 dasupersprint
dasupersprint
  • 848 posts
Posted 28 February 2020 - 04:56 PM
DOT 5 yes.
#7 dasupersprint
dasupersprint
  • 848 posts
Posted 28 February 2020 - 04:57 PM
I'm starting to think I better stick with the DOT 4 then. Plus DOT 5 is crazy expensive
#8 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 28 February 2020 - 05:37 PM
DOT 5 yes.
I think it's been said before but it needs repeating:
DOT 5 is completely wrong for our braking systems ..
It's DOT 4 or DOT 5.1 and even then you should really only use that with NEW empty braking systems!
#9 Spider
  • 14,836 posts
Posted 28 February 2020 - 06:09 PM
DOT 5 is Silicon Based. All others are Glycol Based.
To get the best from DOT5, you need to replace all rubbers in the Brake System, though, with many DOT5, you can retro-fill the system as is, but any advantage of DOT5 won't be realised. You also usually need to top up the Master Cylinder quite slowly to avoid aeration of the fluid. Yes, it's fussy. But once in there, will virtually last forever.
I have one car on DOT 5.
Would I do it again ? No. There's nothing wrong with it, but it's silly money and just way too fussy for my liking.
As Rolf suggested, just use DOT 4 and replace it every couple of years.
#10 nicklouse
  • 18,574 posts
Posted 28 February 2020 - 06:26 PM
DOT 5 also has water issues in that any water that gets into the system will sink to the lowest point(s) and cause rust.
The US forces that developed the stuff have been trying to work out how to get rid of it.
Take your pick of DOT3 or 4 or 5.1 they are all mixabke.
#11 dasupersprint
dasupersprint
  • 848 posts
Posted 28 February 2020 - 06:44 PM
Ok thanks to all of you, will not complicate things and continue with standard DOT 3/4 fluid
#12 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 28 February 2020 - 07:41 PM
The difference between the DOT 3, 4 and 5.1 is the boiling temperature, so if you're driving a street car and not going down mountain roads at 9/10 DOT4 is your best bet, it's also easy to find anywhere.
#13 dunkyb
dunkyb
  • 85 posts
Posted 12 October 2022 - 03:29 PM
Hey guys,
I have a 1965 MK1 which has DOT 5 silicone brake fluid (Atomec) which I assume was filled from dry when it was re-built prior to my ownership.
I am experiencing brake lock-on issues, now having read a lot of negative comments about DOT 5 am wondering whether it's eaten away at seals in the master cyl/brake servo.
If I wanted to move back to DOT 4 or 5.1, would bleeding all brakes with fresh DOT 4 be sufficient, or am I stuck with it?
Many thanks,
Duncan
#14 nicklouse
  • 18,574 posts
Posted 12 October 2022 - 03:58 PM
Hey guys,
Many thanks,
Duncan
Strip clean and replace all seals the fit proper fluid. You may find your cylinders and calipers have rust inside now.
