Kent Cam Identification
Posted 21 February 2020 - 08:20 PM
I've tried Kent but not got any joy, so has anyone any thoughts as to which cam this might be and hopefully some additional specification
Posted 22 February 2020 - 07:48 PM
Probably not a 266 grind, as this has more duration and lift on the exhaust lobe than the inlet - as is the case for most (all?) of their Megadyne cams for the A-Series.
If Kent don't recognise the number KC 5807 then you could use a degree wheel and DTI to check the profile, but this is quite a bit of effort.
Posted 22 February 2020 - 08:19 PM
Are you reading the info on the cam correctly?
got a picture of the stamping?
Posted 23 February 2020 - 02:50 PM
Probably the only way to be certain of the spec is to use a degree wheel and dti as suggested, so will have to wait for a while until I've got a block to use.
Will also have to contact Steve Harris who supplied it way back when.
Posted 23 February 2020 - 08:30 PM
KC could stand for Keith Calver?
Posted 23 February 2020 - 08:34 PM
he uses CST
