What Steering Column Do You Use?
5 replies to this topic
#1 hotroder69
hotroder69
  • 73 posts
Posted 31 January 2020 - 08:51 PM
I'm tring to figure what steering column to run in my pickup with the wilwood pedal setup.
Thanks.  :tumble:
#2 Ethel
  • 25,853 posts
Posted 01 February 2020 - 01:06 PM
I don't think that any original Mini column will be any better or worse than any other.
You could put up some photos if you're having any particular problems or concerns.
#3 Shukran
Shukran
  • 129 posts
Posted 11 February 2020 - 03:40 AM
I am looking at a Flaming River column with Opel (Vauxhall) Corsa EPS
Edited by Shukran, 11 February 2020 - 08:05 AM.
#4 Aroutin
Aroutin
  • 10 posts
Posted 20 February 2020 - 04:32 AM
What kind of master cylinders u intend to use?
I personally recommend the small ones from apracing, in combination with the column lowering kit u wont have any problems.
#5 hotroder69
hotroder69
  • 73 posts
Posted 24 February 2020 - 07:47 PM
I have the Wilwood setup.
#6 hotroder69
hotroder69
  • 73 posts
Posted 25 February 2020 - 07:02 PM
I'm planning to use a mk1 steering collumn but the steering shaft I have some genius welded a steering wheel on the end. After cutting through the gorilla welds I don't have a splines left. I need a replacement one.
Charlie
