so im gonna be replacing the fuse box in my mini its the four fuse glass type , someone said you can get one that looks original but inside it takes the new blade fuses , ive looked everywhere but cant find owt just the old glass fuse type , any thoughts on this cheers
New Fuse Box /blade Type
Posted 27 January 2020 - 09:01 PM
Posted 27 January 2020 - 09:13 PM
I’ve never seen a blade fuse one that looks the same.
if you want it look the same, what’s wrong with using glass fuses?
Posted 27 January 2020 - 09:23 PM
just thought id update to blade type if available
Posted 27 January 2020 - 09:32 PM
This is what I have:
https://www.autospar...rear-entry.html
Posted 27 January 2020 - 09:36 PM
Autosparks supplied a new mini loom to me many years ago with a blade fuse box. It’s a generic one, and I’ve been looking for a more mini looking one ever since, but have never been able to find one suitable.
cheers mate il probably do the same
Posted 27 January 2020 - 11:00 PM
Ive fitted one of these myself;
The mounting holes are the exact dimensions of that of the glass fuse holder, along with being pretty much the same lenght/size.
Only problem is it has one spade terminal on each side instead of two, but i got around that with a dremel opening up the holes slightly so i could fit these;
With a bit of finess they fit great, you could do the same using some piggyback terminals but that means cutting wires you might otherwise not have/want to do.
Fuse holder - https://www.vehiclew...-blade-fuse-box
Spade terminals - https://www.vehiclew...-blade-2-into-1
Edit: Excuse the rust and dirt, just thought i'd add a picture of it fitted.
Edited by Magic jason, 27 January 2020 - 11:17 PM.
Posted 27 January 2020 - 11:22 PM
All I do is remove it and clean the terminals, the rivets and then polish it up. Then I wax the plastic.
They work fine and I think im still using the original on two of my minis
Posted 28 January 2020 - 12:49 AM
Posted 29 January 2020 - 11:52 AM
Wired by Wilson does a blade fuse conversion for a classic mini. It doesn't look like the original though.
6th item down this page:
https://www.wiredbyw...roducts-prices/
