Re-Using Simplex Timing Gears Or Upgrade
22 replies to this topic
#16 duffdub
duffdub
  • 47 posts
Posted 13 July 2020 - 04:57 AM
New Chain = New Gears. I never even bother looking at the condition of what comes off.
As Unburnt suggested, a Duplex set up for a Road Car.
Does the duplex set up require any modification to the timing cover? Specifically on a later A+ 1275
Edited by duffdub, 13 July 2020 - 04:58 AM.
#17 Wazzah
Wazzah
  • 142 posts
Posted 13 July 2020 - 05:59 AM
I'm doing a 1310 rebuild on my A plus too and went for Swiftune's super lightweight simplex set. It has mutiple woodruff keyways which allows a lot of adjustment without the need for multiple keys. Comes with IWIS chain. I believe the 1275 A plus timing covers need a bit of hammering to fit a duplex. Fits in with my reduction of rotating/ reciprocating mass philosophy.
#18 Spider
  • 15,865 posts
Posted 13 July 2020 - 07:17 AM
Most A+ covers have a dimple in them, looking from the front of the cover as it would be fitted on the engine, it's at about 4 O'Clock. These need leveling out with the rest of the cover. Some have said the reinforcing ring (or part of a ring) on the covers that have the Oil Separator also need to be removed, however, I haven't found I've needed to do that.
Apart from the mods to the cover, there's also 2 countersunk screws that need to be fitted in place of the 2 hex head bolts at the bottom side of the engine plate.
#19 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 14 July 2020 - 08:53 PM
Just to follow up on what I decided.
I was going to go with a Simplex ISWS Chain but needed new gears as well so I ended up getting a MiniSpares EVO non-adjustable Duplex Setup.
Still need to modify my Timing Case - and flatten the breather.
#20 duffdub
duffdub
  • 47 posts
Posted 21 July 2020 - 01:04 AM
Is this the dimple you’re talking about?
#21 Spider
  • 15,865 posts
Posted 21 July 2020 - 02:02 AM
That's the one ;D
#22 duffdub
duffdub
  • 47 posts
Posted 22 July 2020 - 06:21 AM
That's the one ;D
How much do you shave off? Looks like if you were to take too much off you’d make a hole exposing the inside.
#23 Spider
  • 15,865 posts
Posted 22 July 2020 - 07:15 AM
That's the one ;D
No Shaving !
Put a steel block under it and use a Dolly on the Inside, then belt it with a hammer ;D
