Hi;
In the middle of a 1275 - 1310 build using a Metro A+ 1275. Planning on fitting an IWIS Simplex Chain from Calver ST and to save money, I was going to re-use my existing Timing Gears. I had not touched them since I pulled the engine apart so took a look at them today.
As I am in no way an expert, I have attached some photos for the experts on here to take a look and give me thier opinion as to whether or not they are worn and should be replaced.
If they are declared not re-useable I can ether buy the IWIS chain above at £35 and the following new gears:
Camshaft Timing Gear Simplex £14.36
Crankshaft Timing Gear £10.25
So with the Calver IWIS that's £59.61 or use a Bull Motif Simplex Kit for £32.34 (which comes with new tensioner) and the CalverST IWIS for about £68, or upgrade to a Duplex:
Calver ST Ultra Light Duplex at £129.50
Or I have just spotted this Steel / Alloy Duplex Vernier version sold by Med Engineering for £135
The engine will be 1310, AC Dodd RS Cam, Stage 2 Head (Standard Rockers), with Stage One Kit, HIF44 Carb - around 80 lb/ft Torque
Any thoughts?
Edited by JonnyAlpha, 21 January 2020 - 06:20 PM.
